Valve Springs
  • dbeardslee
    • Nov 2007
    • 4385
    • Maineville, OH
    Valve Springs
    Anyone know what the service limits are on the inner and outer valve springs? Couldn't find it on the fiche and all my Haynes manual says is 35.6mm for inner and 39.9mm for outer. Unfortunately it only lists these as "fee lengths" and doesn't say if that's what they are new, or where they need to be replaced.
  • Flatlander
    • 288
    • Michigan, Thumb
    "If the free lenght of any spring has decreased more than 2mm (0.008 in) from its specification, replace spring".
    Right out of my book. Hope that helps.
    Flatlander
    '81 XS11H
      I have never heard of anyone floating a valve in these bikes no matter how many miles they had on them. I took my head in last time to get worked on and I actually had one of the outer springs broke... it was still running fine.
      Do what you want, but I would throw them back in (There is a correct end that goes up... tighter wound end to the top) and go.
      • Flatlander
        • 288
        • Michigan, Thumb
        Added too many 0's, it was supposed to be .080 in.
        And it also said to check with a valve spring compression guage. This will also show a symptom of a fatigued spring.
        Flatlander
        '81 XS11H
        • Flatlander
          • 288
          • Michigan, Thumb
          My book says: "NOTE: All valve springs must be installed with greater pitch upward as shown." I think it is saying just the opposite of what you are saying, unless I'm missunderstanding what you are stating.
          Flatlander
          '81 XS11H
          • 79XS11F
            • Jul 2006
            • 3563
            • Ottawa, Ont. Canada
            Greater pinch means more tightly wound ... There is a similar note for fork springs which I am working on and it says greater pinch goes down. The photo shows the more tightly end going in first
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • dbeardslee
              • Nov 2007
              • 4385
              • Maineville, OH
              I was under the impression from a previous post that the tighter end goes down.
              Flat - the 2mm number is helpful, unfortunately I still don't know if the numbers in the book (35.6mm and 39.9mm)are for new or worn. I'll probably end up taking trbig's advice and put them back in. Bike's only got 34k miles on it, but it sat for several years before I got my hot little hands on it and I'm sure some of the springs were compressed during that time.
                You guys are correct, I wasn't. The tighter wound section would go down closest to the valve face.
                The inside spring may be harder to distinguish. One thing you can remember, is that the outside spring is spun in a clockwise direction while the inside spring will be spinning in a counter-clockwise direction. This should help you keep the correct side up.
                Sorry for the mixup.
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  Thanks trbig. I'm mixed-up most of the time anyway, so I barely noticed
                    Apparently, I'm a member of the same club!
                    • 79XS11F
                      • Jul 2006
                      • 3563
                      Speaking of "floating" valves ... the mag I have on hopping up the XS1100 states rather bluntly that the 1100 does in deed float her valves even at moderate RPM. Replacing stock valve springs with heavier springs is considered mandatory for this engine to run its best.
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • Flatlander
                        • 288
                        • Michigan, Thumb
                        Rob
                        I will have to agree with this also.
                        Since I have bent a valve in my 81'h. No marks on the piston at all. I have come to the conclusion that at the time this bent valve happened to me I was in very high rpm's, and floated a or some valves. Well, very high rpm's for a 27 year old valve train. My opinion: If you are running everything original on these, be carefull of high rpm's! Because before you know it "here comes Mr. Piston".
                        I have read that even in installation of the cams, some have installed them incorrectly and while rotating the crank by hand never herd or felt a thing. And had bent sevel valves. So be very carefull and enjoy !
                        Flatlander
                        '81 XS11H
                        • Flatlander
                          • 288
                          • Michigan, Thumb
                          The inner spring is 35.6 mm, Intake/Exhaust. 33.6 mm or less= Replace.
                          The outer spring 39.9 mm, Intake/Exhaust. 37.9 mm or less= Replace.
                          Flatlander
                          '81 XS11H
                          • dbeardslee
                            • Nov 2007
                            • 4385
                            • Maineville, OH
                            Thanks all. Flat - those were the numbers I was lookin' for
                            I appreciate the help.
                            • Flatlander
                              • 288
                              • Michigan, Thumb
                              Direction of coil, could get confused, is from top to bottom. Even if you are holding it upside down.
                              This although will not help you to figure out what is top or bottom of the spring, it will tell you just that it is the inner or outter.
                              Wow that even confused me. Set the spring on the bench, look at it from a over head veiw, if the spring starts in the CW, it's the outer. CCW it's the Inner.
                              Now what I was trying to explain is, now turn the spring over, and they are still the same direction. This CW/CCW direction will not tell you what side is up. It will only tell you if it is a Inner or Outer spring.
                              Flatlander
                              '81 XS11H
