Fork Glitch
    This is for Standard forks...
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      Thanks ... I did manage to get one out with a threaded rod and then while getting other supplies I grabbed a 19 mil bolt and 2 nuts, just like you have there, which worked real well.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • BigDick
        • 521
        • McConnell AFB, KS
        I'll get slapped!
        I stuck a tire iron down the end of mine to hold it. The friggin allen bolts stripped the top, the allen wrench just wollered the hole out. I had to use an easy out to get em loose. I put new bolts in but no loctite or sealer or anything. So I should probably fix that too?
        1980 XS11SG
        Dunlop elite 3's, progressive fork springs, tkat brace
        Stock motor, airbox, carbs, exhaust
        ratted out, mean, and nasty
          The locktite really isn't necessary, but if you do use some, use the blue type. Although, you should use those copper crush washers. BTW, the above pictured tool won't work on the Special forks. There isn't a 12pt. socket in the damping rod, it's just round.
            Pull the Damper bolt FIRST!
            The trick that's always worked for me when disassembling Showa forks is pull the damper rod bolt FIRST; before you pull the fork cap or spring out. The spring sits on top of the damper, and the preload has always been enough to keep the damper from turning.
            Of course, you now have a giant leak and the old fork oil gets everywhere, but it pretty much does anyway, so....
            And for you guys with extra lower trees or parts bikes; a spare lower tree clamped in a vice makes a dandy 'fixture' for working on the forks, and no worries about boogering the tube.
            '78E original owner
            • oseaghdha
              • 1075
              • N43.02.5,W88.14.2
              Have not tried this, so......
              No guarantees.
              For what it's worth, on my vintage dirt bike forks you screw a bolt in thru the drain hole which locks the inner from turning. Then you can then remove the bottom bolt. Reverse to assemble.
              YMMV
              XS1100SF
              XS1100F
              • geniusloerts
                • Jul 2007
                • 420
                • fayetteville, Arkansas
                hey guys,
                I am doing my seals today, pulled mine apart and there apears to be 2 seals per tube...this is on a '79 special..... there is the normal seal that i got off line but there was a smaller seal, as far as height goes, under that with a big washer under it.
                sooooo whats the deal? do i need to get these others? and where? i didnt see them on the site i got the regular seals from.
                thanks as always
                -Genius
                1979 XS1100 SF "Black Goblin"
                -Pod Filters
                -4-1 pipe
                -larger jets for carbs
                1982 XJ1100 "Black Sheep"
                • 79XS11F
                  • 3563
                  Yes the forks have 2 seals per leg. You have the larger outer "dust" seals and the inner "oil" seals. If the forks are not leaking oil the inner seals can be left alone. If their leaking oil then the inner seals need to be changed and your outer dust seals may still be good.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
