Float height adjustment
  • ruffrider
    • Mar 2008
    • 60
    • Stanwood, Washington
    This may seem like a silly question but the clymer manual that I'm using doesn't tell me if the float needles should be seated all the way or just the weight of the floats resting on the tabs for adjustment. Do I seat needles then measure 25mm or leave them just resting???
    1979 XS 1100 SF(16k now, more to come)
    140 mains, 42.5 pilots, drilled airbox w/uni fliter
    MikesXS Coils- bypassed ballast resistor- new wires
    1975 GL1000 Gold Wing(81k-Old Faithful) and another 75 GL1000 project. MBS sickness for sure.
    Other Bikes Iv'e owned:
    1979 Kawasaki 750 LTD
    1980 Kawasaki 125 Enduro
    1975 Honda 400f
    1976 Honda CB360
    1968 Honda 160
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    'I need a rest."
    Just resting. No pressure.
    The float needles are already seated all the way. The weight of the float does not compress that little springy thing.
    Best as I can figger it.... that little springy thing act as sort of a shock absorber.
    As the bike uses fuel and the bowl refills... as the bike twists and turns and the fuel level rises and sloshes... were it not for the "springy nipples" on the needles(I like that term!), the float adjusting tang would eventually bend, throwing off your float height measurement.
    • ruffrider
      • Mar 2008
      • 60
      Thanks! That's what I thought but wanted to be sure. Thanks for the quick reply.
      1975 Honda 400f
      1976 Honda CB360
      1968 Honda 160
      • prometheus578
        • Aug 2004
        • 4012
        • Olympia , Wa.
        "Oh, and welcome to the site."
        Also, there is some confusion concerning measuring the float height. It is measured with the bowl gasket in place on the carb.
        • ruffrider
          • Mar 2008
          • 60
          Wow is that good to know cuz that a considerable difference... at least a silly milimeter or so. Thanks again, Prometheus
          1975 Honda 400f
          1976 Honda CB360
          1968 Honda 160
          • randy
            • Dec 2003
            • 4521
            Prom, get another cup of coffee.
            All the manuals I have say to measure without the gasket in place.
              Just to toss in another perspective - I've always felt it does not really matter if you measure with or without the gasket, or whether you hit 23 or 24 or 25 mm, at least not the first time you do this. The first goal is to get all four floats exactly the same i.e. within 0.5mm of each other, closer if you have the patience. Then you put it all back together, do a thorough sync/colortune/resync, and ride it for a short bit. Next, you check performance, look for flat spots, do a plug chop to check plug color, and check fuel consumption. Only after all this, can you go back and figure if your floats need to be set higher or lower.
              IMHO, chances of hitting it dead on the first time by setting to a number in the shop manual is a long shot, considering all the variables that come in to play with a 30 year old motor, altered exhaust, monkeyed-with jets, modified air filters, etc, etc.
              YMMV...
              • AlanB
                • Oct 2006
                • 705
                • Scotland
                hi Ken,
                Very difficult to put it better..........
                AlanB
                If it ain't broke, modify it!
                • prometheus578
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  I am in Randy's debt."
                  Now that's odd....
                  Not the part about being in Randy's debt, though t'is quite an oddity, but that I am mistaken.
                  How can this be?
                  Truth be told, I've always measured from the bowl "Without" the gasket in place. But, as there has always been some debate upon this point, a few days ago I went on a self search for answers.
                  The Clymers was too vague..."Measure the distance from the bottom of the float to the float bowl gasket surface." Poorly worded, at best, and one can see the cause of the confusion.
                  I next checked the Yamaha service manual. Somewhere, though I cannot find it now, I found an equally vague instruction which, at the time, seemed to reenforce the measure from the gasket idea.
                  What, there it is... Page #4-3, "B" specifications:
                  Float height: 25.7mm +/- 1mm (above gasket surface).
                  So, to my addled mind yesterday... It seems that all has been decided then. Keep the gasket in.
                  Yet, here comes Randy with his "Prom, you're an idiot" attitude.
                  Ok, tough guy.... I know what I read. I can read between the lines and infer stuff, etc.
                  I'm typing a reply when I stumble upon page #4-5... and there it is, in black and faded yellow white....
                  Float level adjustment....:Measure the distance from the bottom of the float to the float bowl gasket seating surface without the gasket."
                  How I missed seeing that yesterday, I'll never know.
                  Ok... All praise to Randy, for helping confirm something that some of us already knew and some were undecided on.
                  Now, don't everyone go jumpin' on ol' Prom...
                  Thing like this happen.... even with proceedures that one feels are common sense.
                  One will find differences in measuring float height between different brands of bike.
                  Ruffrider's question about the needle's spring/ press down on the float isn't so silly.
                  On our carbs, the float height is measured with the carbs turned upside down. On other carbs, one tilts the carbs at an angle, so that the float tang just "touches" the spring loaded rod on the needle.
                  But, coffee does sound good right now, Randy.
                  • 79XS11F
                    • 3563
                    • Ottawa, Ont. Canada
                    Re: "Oh, and welcome to the site."
                    It is confusing but ... the measure is to be taken with the gasket removed. This is for the 1978 model from the factory manual ,section 4-4 on carburetor adjustment.
                    "Measure the distance from the bottom of the float to the float bowl gasket seating surface without the gasket"
                    Rob
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
                    • jjwaller
                      • 242
                      • Gautier, MS
                      Is it just my carbs?
                      I've tried the measurement method on the Mikunis and I always have to use the sight tube method to get them dialed in. Measuring the floats on mine has no relation to reality. Just curious, are my floats really that mangled? Honest, not me.....The PO. That's my story and I'm sticking to it!
                      John
                      '81 CB900C ( 10 Speed)
                      '78 CB750F ( The F)
                      '76 CB400F ( The Elf)
                      New '82 Honda MB5 Ring Ding
                      Then: '76 CB550K
                      '78 CB750F
                      '84 VF1100S
                      And still Looking!
                      • SFerinTEXAS
                        • Jun 2006
                        • 877
                        I also use the sight tubes as a standard rule. Best to know than to expect.
                        79SF
                        XJ11
                        78E
                          • 7830
                          SFerinTEXAS:
                          Grasshopper!! Once you have attained the proper state, you will be able to dial in the carbs with the float height!
                          It's all a matter of experience. After a few sets of carbs, they get easier to adjust. Just ask PROM, IF you dare!
                          • SFerinTEXAS
                            • Jun 2006
                            • 877
                            No offense DR but i do believe in what I can see. A while back I was cleaning extra brass floats and put 8 in the carb cleaner pot . Got distracted and forgot them for a few weeks. When I pulled them out 4 had taken on fluid. The leaks could be so small that a short soak may not have shown the problem. Maid me wonder about the ones I didnt test so long before. Using the modified grease fittings it only takes a few minutes to double check. BETTER TO SEE THAN EXPECT. With all do respect.. Sorry I missed you when you came to get PATHFINDER. I was not Worthy
                            79SF
                            XJ11
                            78E
                            • ruffrider
                              • Mar 2008
                              • 60
                              Jeez, look what I started! No really, I enjoy all the friendly banter and good tips on this forum. Thanks to all. I hope my good buddy "The White Buffalo" who left me his 79 special is smiling down from heaven enjoying my journey. Any ideas where to get a float bowl screw plug with a tube so as to attach a clear hose?(Maybe the plumbing supply at the hardware store.) What I really need is a lot more time. Damn job gets in the way.
                              1975 Honda 400f
                              1976 Honda CB360
                              1968 Honda 160
