Kick Starter?
  • erithanis
    • Dec 2007
    • 89
    • Sunnyvale, CA 94089
    I just found the kickstarter this weekend. Never knew it was there. I'm going to try starting the bike with it, simply for ****s and giggles.
    Looking for an XS
    79 XS1100SF (RIP)
    - stock standard headers(stupid PO), slip-on after-market mufflers.
    - after-market rear shocks (PO installed)
    - no airbox, POD filters
    Misery remembered is ADVENTURE!
    • jurgenkoppen
      • Jul 2007
      • 97
      • Powell River, BC Canada
      any xs850/xs750 will fit
      Hey Ross and Cobia and all
      any of the xs750 or xs 850 foldable kick starters will fit on a 78/79 xs11 engine's kicker stub .
      I found with mine, that it is best to install the kicker as far away from the engine housing as possible, because if it is too close, the kicker will rub on the brake pedal when you kick down on it.
      You will need to dremel a little channel into the kick starter stub to allow the pinch bolt to go past the stub.
      Other than that, it is all easy.
      I am not sure about putting the inner kicker assembly into a 80's engine without stub, but I remember vaguely reading in this forum that it would be very involved to do so.You might run a search, but I think it would require splitting the engine housing, to get the bearing assembly in.
      Top Cat would know....
      Cheers, Jurgen
      80 1100SG with 79 engine
      79 1100F being restored
      78 xs650 runabout (mpg, eh?)
      Irreverence is the champion of liberty and its only sure defense
      • ross
        • Dec 2006
        • 542
        • see signature...
        deja vu.....
        hey jurgenkoppen...thanx for the info but ya only gotta reply once....talk 2 ya later..ross
        rebel devil
        1979 xs 1100f standard
        authenic historical vehicle
        42°36'23.52"N, 82°52'44.78"W
        "I'M IN MY HAPPY PLACE"
        "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
        "if you don't wrench on it, get behind me satan!"
        '96 venture cct.....installed!
        stainless, braided, pvc coated brake lines
        i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
          • 7819
          Ross & jurgenkoppen;
          I took care of the "extra" posts. They were ONLY in your mind....
