I have read my Clymer's and the many threads dealing with the cam chain tensioner. I have the oil leak from the plug that seems pretty common. It looks as though a PO has fixed it with a small metal plug of some sort and filled the around the top and sides with JB Weld(?). There is a small indentation on the bottom that seems to be the source of the leak.
If I turn the crank so the pointer is to the "C" can I loosen the adjusting bolt and remove the housing? I guess more importantly, would I the be able to simply reinstall the bolts and tighten the adjuster if I did not move the crank? How should I go about removing the old fix? Or should I just try to get a little silicone into the indentation?
One more question. I believe that I have an oil pan gasket that is leaking. Can I just buy a sheet of gasket at the auto parts store and cut it myself, or is this a rubber o-ring like gasket? I am changing the oil tomorrow, so I'd rather fix it than wait for a part.
Dave
Dave
