oil change
  • conky1980
    • 19
    • Creston South, Newfoundland, Canada
    oil change
    This might sound like a stupid question, but when doing an oil change on 82 xj11 is there anything else to do other than remove the drain plug and change the filter. I have a 05 Yamaha atv and you have to drain the cylinder head with an oil change, do you have to do anything like that with the xj11? Also wondering what type of oil is best to use. Thanks.
    1982 XJ1100
  • randy
    • Dec 2003
    • 4521
    conky,
    Doing an engine oil change on these machines, just the crankcase oil and filter get changed. Some of the better filter brands also include new o-rings for the filter cup.
    The best oil to use? If you do a search here, you'll find about a hundred different opinions! In all of my air cooled applications, I've always used Castrol 20W50.
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      I know that a Fram CH-6002 filter includes the cup O-ring as well as the center screw O-ring. I have used Castrol 4T cycle oil, 20W50, with great results (clutch seems to like it).
      Mike Giroir
      79 XS-1100 Special
      • beegshot
        • 85
        • South Carolina
        IIRC, the XJ11 uses the same filter as...
        the Mighty V-max (85-95). Or, more appropriately for this forum, the Mighty V-max uses the same filter as the XS/XJ11.
        Look Here: http://www.vleonline.com/pdf/fram.pdf
        Robert
        XJ1100 - Stock
        XV750 - POS parts bike
          but wait, there's more!
          My EMGO filter don't have the filter bowl o-ring in the box with it but it does say VMX 12-MAX 85-95 XJ1100 MAXIM 82, XS750/S 77-80, XS850/L/S 80-81, XS1100 ALL 78-81, XVS12/13 ALL 83-94.
          Now if I could afford to own all those different machines would I care about having to only keep one style of filter for them? Perhaps not but it surely lessens a dealer's inventory problems.
          • mro
            • 4276
            • Hayward, California
            Changed oil on daily ride last week.
            The o-rings that came with the fram filter were right diameter (length) but were too skinny, so wound up using the old ones
            mro
            • mason79
              • Mar 2006
              • 1351
              • los angeles, ca
              i did 4 changes with old o rings and it is still holding, just don't tighten the housing bolt too much you'll regret it. and make sure the spring and washer goes on the housing first then the filter
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
                Filter from NAPA contains both rings also.........NAPA Gold4933
                • TADracer
                  • 1417
                  I thought that too the first time I used the Fram filter so I installed it all and watch closely for leaks and there were none. But I do notice that when you remove the filter for the next oil change the o-rings are fatter than they were when you put them in and are definately fatter than the new o-rings. It appears that they swell on first engine heat or something.
                  Anyway, the Fram filters seem to work OK.
                  Mike Giroir
                  79 XS-1100 Special
                  • boyat68
                    • Oct 2007
                    • 358
                    • Virginia
                    I just heat the Fram o ring in a pan of boiling water for a few minutes. This straightens out the curl and fattens the O up so it fits better.
