Rotor Testing
  • Filter
  • Rotor Testing
    I am replacing the stator on my bike, and want to know how to test the rotor while I'm at it.
    I put some tools around it and noticed the center part had a weak but noticeable magnetic field.
    79 XS1100 Standard
    Thanks,
    Eric
  • #2
    You're testing the field coil/rotor. The magnetic attraction test is the right test, so sounds like your field coil is working OK. There is no test for just the rotor.
    • #3
      Well, I actually did that test after taking the stator assembly off, but either way produced a noticeable field
      thanks
      • #4
        Electrical
        Before any difinitive electrical tests...
        have you cleaned the connectorss/plugs ???
        An XS thats been sitting has a tendincy for corrosion which can result from low charging to miss-firing or the turn signals not blinking..etc..
        mro
