By-by, MSD
  • 81xsproject
    • 3185
    • Fortuna, CA
    By-by, MSD
    Well, I have decided to yank the MSD iggy. It has done my more bad than good. It stole my midrange for whatever reason, top end is about the same, starts a little easier. So what I want to do is see if I can keep the coils. They are 1.5 ohm MSD coils. This came up before when I want to test the bike one component at a time and someone said something about using a ballast resistor so I could run it with my stock iggy...? Can it be done, or should I just try to sell them and get different high perf coils?
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    You may be able to run them with the resistor, but your TCI box isn't set up for it. I would just go with the Mikesxs HP coils for $35 each. Or, you CAN spend about $100each for some Accel coils that put out about 10% more. Your money, your call.
    • 81xsproject
      • 3185
      • Fortuna, CA
      I think what I will do is sell them, and hold out to do the GM DIS with the Megasquirt like Stan did. However, I haven't got to test the bike with the stock coils back on to make sure that is was the MSD robbing me of power and not something else I screwed up when I had everything apart. I am also trying out the 'Coil Repowering Mod' that works so well on some of the other old bikes like my buddies KZ.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
