Rear Shocks
  • Peter
    • 68
    • Hamilton/Ontario
    Rear Shocks
    Hello.....has anyone R/R the rear coil springs on there 1100 MS?? If so how is it done and how easy is it? Was it worth it?
    Tks
    Peter
    (Moderator note - move your note over here to the tech discussion area, Peter, should get a bit more feedback here. KT)
    Hi Peter,
    here's a trick I read about on another list concerning how to get the springs off a rear shock. It sounds scary so wear the same full face mask you'd use for heavy duty angle-grinding.
    Take the center piece out of a hydraulic scissor jack to leave a hole the bottom of the shock will fit in. Run a loop of chain with 2 sturdy hooks on it under the jack and put the hooks over the spring's coils as high as they will go. Pump the jack and the chain will tighten to compress the spring. Now you can take the keeper pieces out and release the jack to let the spring extend to be lifted off. You REALLY want to do this?
      spring compressor
      Here's what I use to compress those shock springs. Home made and works very well.
      • COOL TOM
        • Jul 2005
        • 288
        • CANTON, IL
        Shocks springs
        Somewhere on this site is a article about building a hyd press to take the springs apart. It works because i built one and have taken at least 6 shock springs apart with it. Maybe someone who knows where it it can post it here. Like fredintoon said make sure you make a bracket to hold the bottom of the shock. It is real easy with this press.
        Thanks Tom
        82 XJ DAILY RIDE
        78 XS1100E FIXING UP
        79 XS1100F PARTS BIKE
        79 XS1100SF NAKED BIKE
        80 XS1100SG FULL DRESS BIKE
        82 XJ IN THE ROUGH
        • Peter
          • 68
          • Hamilton/Ontario
          THanks for the tips....I will definetly pick up some now when I get the chance..:-)
