Choke lever repair help needed
  • SanDiegoMike
    • Oct 2005
    • 192
    • Near the beach!
    I know I've seen it here somewhere...someone did a pretty creative repair for their broken choke lever by using a small hinge. I can't find that thread anywhere, and I need to see how it was done because my lever broke this morning. Can someone please point me in the right direction? Thanks!
    Hi...my name is Mike, and I'm a lane-splitter.
    '80 XS1100SG (mine)
    '87 CMX450C Rebel (daughter's first bike)
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    Pretty sure that was a TC mod
    mro
    • mro
      • Oct 2005
      • 4276
      Click...
      mro
      • SanDiegoMike
        • Oct 2005
        • 192
        • Near the beach!
        Thanks for the quick response! Is there a way to make the photos bigger? I need to be able to see the detail better so I can put the holes where they need to be. Thanks again!
        '80 XS1100SG (mine)
        • mro
          • Oct 2005
          • 4276
          Can right click on a pic, go to properties
          copy address
          paste in address bar...
          mro
            • 8767
            my 2 cents
            This is how I eliminated that knee-scraping choke lever. Knob just screws right on existing choke shaft. Done.
              • 7738
              Mike,
              The reason they break is poor maintenance! You NEED to oil the choke shaft at all the points it travels through the carb bodies. I use a spray silicone lube on mine, and it seems to last about six months. I also ride about 24K miles per year.
              • Dragon Tamer
                XStremely XSive(Deceased)
                • Sep 2006
                • 426
                Now I like that little mod that BikerPhil did there, I may have to steal that idea if you don't mind Phil. I ain't that my lever is broken, it is just that when I have the Vetter lowers on the fairing (which I do except in warmer weather) they interfere with the action of the lever. That there little knobby jobby looks to be just the ticket to solve that problem.
                Thanks Phil!!!
                The Old Tamer
                _________________________
                  • 8767
                  knobber
                  Go for it. It is easy to operate as long as choke shaft is lubed. 99 cent knob from home depot and thread lock blue.
                    Hey MRO,
                    Thanks for finding that old post. I sorta fixed it so that at least the photos are NOW active links to the larger images on the photodump site!
                    But Phil, I like your approach and idea as well.
                    Shows more than one way to fix a problem!
                      • 8767
                      forgot to mention
                      Might have to run a die over the choke shaft, 8-32?, so it threads on nicely.
                      • SanDiegoMike
                        • Oct 2005
                        • 192
                        • Near the beach!
                        Couldn't agree more, Ray. PO wasn't as loving as he should have been, and I've been nursing the lever since I've owned the bike. Got it fixed now though, and it works great!
                        '80 XS1100SG (mine)
