Carb jet conversion
    • 6753
    cool
    Thanks DB....
    1980 XS650G Special-Two
    1993 Honda ST1100
      • 6753
      ok just checked out the parts cache and I found what DB was referring to however... there were two sizes given for a main jet...one said #170.0 and another listed says #112.5 so just wondering abt this?
      1993 Honda ST1100
      • randy
        • Dec 2003
        • 4521
        Ben,
        I just checked the fiche. Your main jet is part #40 on the list. the other one is a main AIR jet. Your stock main jets are 112.5 .
        40 620-14231-73-00 JET, MAIN (#112.5)
        • randy
          • Dec 2003
          • 4521
          Also, the table says go up 1 PILOT jet size for every 3 main size increases. So you'll need one size larger pilot jet. Your stock pilot is #47.5, one up would be a #50.
          • dbeardslee
            • Nov 2007
            • 4385
            • Maineville, OH
            Sorry about the confusion. I should have looked more closely.
            • geniusloerts
              • Jul 2007
              • 420
              • fayetteville, Arkansas
              hey, just a fast uestion while the subject is up, will the jets from Mikesxs.com work? they are for mikuni carbs.
              1979 XS1100 SF "Black Goblin"
              -Pod Filters
              -4-1 pipe
              -larger jets for carbs
              1982 XJ1100 "Black Sheep"
              • dbeardslee
                • Nov 2007
                • 4385
                • Maineville, OH
                Genius,
                I just put n100/604 mains and bs 80/96 type pilots in mine and they work great. I got them from Jets R Us but mikesxs has the same parts for less money.
                DB
                  • 6753
                  Thanks Randy!I will be looking as to where to find the best prices...although this isnt expensive right?...so applying the rest of the formula to what we now know...112.5 stock size...up 4 jet sizes over stock * 2.5 = 10 so the new jetting should be 122.5 coupled with the pilot jet going from 47.5 to 50.0
                  1993 Honda ST1100
                    • 6753
                    one further question
                    Seeing that I bought the Dynojet kit last year...it has occurred to me that there might be better brands or manufacturers...any suggestions...?
                    1993 Honda ST1100
                      • 6753
                      Learning quickly
                      Ok I think I will go with the Mikuni jets...lol...one problem i see on the jets r us site is that four sizes over stock (112.5) is actually 125.0 so thats not exactly what i was expecting in terms of the formula previously applied..comments?
                      1993 Honda ST1100
                      • dbeardslee
                        • Nov 2007
                        • 4385
                        • Maineville, OH
                        I looked at MikesXS and their main jet sizes jump from 120 to 125 also. They do have a 122.5 main jet, but it's the kind with the small head.
                        • randy
                          • Dec 2003
                          • 4521
                          Cycle Recycle has the mains, but not the pilots.
                          CRC2online
                          • red bandit
                            • 950
                            • central michigan
                            Stock pilot jets are 42.5 not 47.5. I think Randy had a typo. If you put a 50 pilot jet in....it's way to big.
                            79 SF parts bike.
                            • randy
                              • Dec 2003
                              • 4521
                              For a 79 standard, you're right.
                              Look up the fiche for an 82 XJ, it lists 47.5 pilots.
                              • red bandit
                                • 950
                                • central michigan
                                I thouhgt he was talking about an xs. SORRY.
                                79 SF parts bike.
