accel super coils
  • Steven
    • 1
    • Surprise Arizona
    accel super coils
    Does any one have accel super coils on their bike. If so how did you mount them?
    Steven 1981 xs1100sh
    frame up restore in progress
  • 81xsproject
    • 3185
    • Fortuna, CA
    Welcome aboard. It helps if you add your year/model info to your signature in order for others to help you. I believe there is a write-up in the tech tips pages. Most answers are either there or can be found with a quick search as most questions have come up before.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
      accel coils
      This is how I mounted accel coils on a Special. Left side in normal position, right side pointing down. Black paint so they'e not visable. It's a tight squeeze. Might need to get a shorter bolt for the rear mount.
      • raqumup
        • Feb 2004
        • 94
        • Ashburn, VA
        i mounted mine in the same place that the old ones came off of. i atached the brackets that the coils came with to the coils and used screw hose clamps around the brackets and wraped the clamps around the tube frame of the bike. have had them there for 6 years and had no problem, and you cant see them. they are tucked up under the tank.
        79' XS1100SF
        • gene
          • Mar 2009
          • 267
          • Weston, Fla.
          Last edited by Ken Talbot; 06-06-2009, 09:11 PM. Reason: fixed img tags - removed unneeded stuff
          Gene (Florida)
          1980 XS1100SG
          Accel Coils
          4-1 Jardine Exhaust
