What size bolts for the carb bowls?
  • GrandPrix46
    • Mar 2008
    • 66
    • Converse, TX
    Anybody know what size/thread bolts go in the bowls? Bike didn't come with any, and of course when I re-did the fuel lines and put some gas in, it started pouring out from the bottom. I assume they will also need copper washers, where's a good place to get those?
    '07 Virago
    '80 XS11G
    '78 XS11E
    '97 Grand Prix GTP
    '99 Grand Prix GT
  • 81xsproject
    • 3185
    • Fortuna, CA
    I know that they are M5's
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      metric
      IIRC they are M8 x 1.0
      MDRNF
      79F.....Not Stock
      • randy
        • Dec 2003
        • 4521
        Fellas, I believe he means the drain plugs, not the bowl screws.
        • GrandPrix46
          • Mar 2008
          • 66
          • Converse, TX
          Sorry for not being more specific, but yes, it's the drain plugs that are missing. Also known as the bleeder screws.
          '07 Virago
          '80 XS11G
          '78 XS11E
          '97 Grand Prix GTP
          '99 Grand Prix GT
          • randy
            • Dec 2003
            • 4521
            FYI;
            Those screws are special, they have a tapered tip. Any old screw won't do the job. IIRC, been a while, but I had the same drain cocks on my '81 Special. They also have an o-ring on them?
            • GrandPrix46
              • Mar 2008
              • 66
              • Converse, TX
              So it's a dealer-only part, then? That sucks, guess i'll start calling around and see if anybody has them.
              '07 Virago
              '80 XS11G
              '78 XS11E
              '97 Grand Prix GTP
              '99 Grand Prix GT
                carb parts
                You can probably source them from www.motorcyclecarbs.com as an alternative.
                • randy
                  • Dec 2003
                  • 4521
                  Or Andreas!
                  • red bandit
                    • 970
                    • central michigan
                    81 are they only one's that have that style (horizontal). The 78,79,80 have a brass hex bolt that goes up into the bowl in a vertical position. GrandPrix, which do you have? Horizontal or vertical?
                    79 SF parts bike.
                    • GrandPrix46
                      • Mar 2008
                      • 66
                      • Converse, TX
                      They're vertical (go up into the bottom of the carb). I'll check that motorcyclecarbs.com out.
                      '07 Virago
                      '80 XS11G
                      '78 XS11E
                      '97 Grand Prix GTP
                      '99 Grand Prix GT
                        If you're looking for this:
                        it is a M8x1.25 approx 6mm long, 10mm head size, brass if you can find it.
                        • GrandPrix46
                          • Mar 2008
                          • 66
                          • Converse, TX
                          That's the one. Thanks bro, i'll hit up home depot or autozone tomorrow and see what I can find.
                          '07 Virago
                          '80 XS11G
                          '78 XS11E
                          '97 Grand Prix GTP
                          '99 Grand Prix GT
                          • randy
                            • Dec 2003
                            • 4521
                            I thought there was a carb change in '80, the bowls didn't change till '81?
                            • red bandit
                              • 970
                              • central michigan
                              They did change the carbs in 80. 80 & 81 bowls will swap but the 80 take the same drain plug as 78-79, 81 has diff. drain "screw" with down spout for tube hook up.
                              79 SF parts bike.
