I don't know when the 4 ways started. Later years have them but my 78 doesnt.
High Output Alternator....interest?
Theodore Roosevelt -
Yes, it DOES work, and very well. However, at idle, the system does not charge the battery with either the OEM or Geezer's Reg/Rect. The OEM one doesn't start charging until the RPMs are up to about 2500, where Geezer's starts much lower, at about 1300-1500.
The 4-way switch, if it is there, is located on the underside of the turn signal switch housing. You can't miss it. The flasher for the 4-ways would be located just forward of the battery, under the seat on the left side, just inside the top frame rail.1980 XS850SG - Sold
-H. FordComment
Thanks, guys. I have seen a picture of later models where it (4-way) is under the switch and noticed mine doesn't match up.Richard
'79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
'02 Honda VTX1800CComment
Got it, Bug. So it's not such a great benefit unless you like to ride around lugging your engine, eh? Where we could really benefit is if it would charge AT IDLE. Then when you really need the xtra juice, like in slow traffic, you'd be ok.Former owner, but I have NO PARTS LEFT!
Actually, The Geezer one charges at a better rate (not sure of the specs) than the OEM one, so it IS a benefit all the time. Most vehicles don't charge at idle - even cages.
The "extra juice" is for charging, and generally most important for longer runs. You want to be able to supply power to all the aux things for long stretches without draining the battery.1980 XS850SG - Sold
-H. FordComment
I guess the question is the definition of "charging". If you car battery is dead, and you jump start it and only let it idle, generally, you won't be in any better state 20 minutes later. If you jump start it and drive the freeway for 20 minutes, you'll be able to start it again after shutting it off.1980 XS850SG - Sold
-H. FordComment
Nice try.......still not true C.Bug.......81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Go put a voltmeter on any cage while idling and you'll see 14+ volts if the system is working properly. If it didn't charge at idle, you'd see cars stuck on the road during a night time traffic jam.2H7 (79) owned since '89
☮Comment
Most car/truck alternators do have usable output at idle; that was the main reason they made the switch from generators. Not full output, but usually enough to keep the battery charged if you aren't running everything. The heavy-duty versions can manage even that; think emergency vehicles.
Those of us old enough to remember cars with generators can recall the dull red glow of the charge light while sitting at stops...
-H. FordComment
Generators
Yikes.. I remember generators!! Somebody get me a cane!!!78 XS1100E Standard
Coca Cola Red
Hooker Headers
http://i408.photobucket.com/albums/p...m/DSC00580.jpg
1979 XS1100 Special
http://i408.photobucket.com/albums/p...m/DSC00612.jpg
1980 XS Standard
http://i408.photobucket.com/albums/p...m/DSC01137.jpg
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
A car's alternator should always be charging between 13.5 and 16 volts, no matter if at idle or above. What changes with RPM's is the amperage. Most of todays vehicles use 105-120 amp alternators.Richard
Just pull that switch apart and clean it out (it likely has old dried grease/lube in it) and put some fresh dielectric grease in it and your will be shocked at how much easier it works after that.Since we are on the subject of lighting/electrical, does the '79 have a "4-way flasher" function? I have yet to figure out where it is.
C Bug-I wish my bike had the auto cancel for turn sigs. My switch is very stiff and sometimes proves difficult to shut off. Usually pushes too far over and turns the other side on! Someday I'll replace the switch.Cy
