High Output Alternator....interest?
  • thewiz
    • Oct 2006
    • 1115
    • Wilksboro, NC
    Hobbyman and others ...
    Planedick is workin' on a high output alternator too .... believe me when I tell you, if he says he can make it, he can. Don't know where he's at on the project .... and for some reason, he hasn't posted on this thread .... Planedick ... you're exposed, might as well weigh in :-)
    80G Mini-bagger
    Past XS11s
    • planedick
      • Mar 2005
      • 2068
      • Yorba Linda, California
      discoveries
      I have found that the cost is prohibitive. Necesitates remaking of laminates to facilitate larger wire and more windings. I've been thinking of making the field part stronger, but there is the probability of creating an overcharging situation. I'm not sure if the regulator can compensate as regulating the field is the most common way used to regulate the charge rate. Additionally, the higher rate will cause an overheating condition in the windings and possible failure. Project is on indefinate hold.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
      Custom security system
      Stainless braid brake lines
      • AustinPhoenix
        • Mar 2008
        • 112
        • Austin, TX
        awww
        "And like that (blows) he was gone"
        Thanks for crushing all of our hopes and dreams.
        1980 XS11g Standard - "Ash"
        4 to 2 Exhaust
        K&N Pod Filters
        Fuel Filters
        Inline shut off valves
        Slotted Rotors
        My heart and soul
        Soon to have stainless lines, xs750 FD, lightened rotors, and HID headlight
        1979 Special Project Bike
        Non-gasoline conversion
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          FJ
          Are the FJ alternators good candidates for an upgrade to the xs11?
          MDRNF
          79F.....Not Stock
          • GNEPIG
            • Apr 2005
            • 1656
            • fl
            The FJ alternators are mounted up on top of the transmission/ behind the cylinders.
            • mro
              • 4276
              • Hayward, California
              not a problem for xschop
              mro
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                what I'm thinking
                I know that the FJ alternator goes there. It also has two 180 degree bolt holes that could mount to a custom adapter....chop
                MDRNF
                79F.....Not Stock
                • Cyclechrist
                  • 13
                  • Bedford MASS
                  Hi There Bigger would be nice
                  [QUOTE=Geezer;147286]How much would it be worth to you to double or triple the charging system output on your bike?
                  I have a system in the design stage at the moment that is promising 45 to 60 amps output. It would include a custom alternator cover that would be a little bigger than stock one. Personally the stock 20 amp alternator has always been enough for me but from time to time the subject comes up.
                  Right now I have the kit price penciled in at around $250 and it could go a bit higher. How likely are you to buy something like this?
                  On the other hand once I have all the details worked out it would be pretty easy to adapt the kit to other bikes.
                  Geezer[/QU
                  I would be very interested in bigger alt... I am putting a front fairing and radio with amp in looking to up the out put. AMPS
                  • XSive Okie
                    • Jun 2010
                    • 281
                    • Enid, OK
                    I would be interested as well. With a radio and 12 lamps around the trunk, my headlight stays dim until the RPM's come up, so I usually run it on high beam. Anything to stay as noticable as possible!
                    Richard
                    '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
                    '02 Honda VTX1800C
                    • scoot
                      • Dec 2007
                      • 153
                      • Poway, CA: San Diego County
                      You sound to be a perfect candidate for one of Geezer's regulator/ rectifier units. An amazing piece of wizardry that gets you that needed power starting at lower rpms from the stock gear. Let me be the first to suggest you check it out.
                      scoot
                        I have Geezer's Reg/Rect, and it does make a difference in output at lower RPMs. I have LED lights in my trunk and tail light, and a fairing with an HD Radio (no amp). I recently upgraded to a 35W HID headlamp, and that lowered the current draw as well. I kept the stock turn signals because I like the auto-cancel feature. I still see some dimming in the dash lights (still stock too) when the signals flash, but the HID headlamp (by design) does not dim once it's fully warmed up.
                        I've run for hundreds of miles with a GPS charger plugged into my fairing without a problem, and that was before the HID headlamp upgrade. If you change all your aux lights (trunk/tail) to LED's you'll see a noticable difference, but your stock headlight will always be noticeably dimmer at idle, since the system (even with Geezer's Reg/Rect) does not start charging until the RPM's go up.
                        • XSive Okie
                          • Jun 2010
                          • 281
                          • Enid, OK
                          Since we are on the subject of lighting/electrical, does the '79 have a "4-way flasher" function? I have yet to figure out where it is.
                          C Bug-I wish my bike had the auto cancel for turn sigs. My switch is very stiff and sometimes proves difficult to shut off. Usually pushes too far over and turns the other side on! Someday I'll replace the switch.
                          Richard
                          '02 Honda VTX1800C
                            It has self cancers Richard, you just need to have the right flasher, incandescent bulbs and clean the switch.
                            • DAVINCI
                              • Jan 2011
                              • 1048
                              • Cedar Mountain, NC
                              I have Geezer's Reg/Rect, and it does make a difference in output at lower RPMs. .................................
                              .................at idle, since the system (even with Geezer's Reg/Rect) does not start charging until the RPM's go up.
                              Huh? So it does work or it doesn't?
                              • XSive Okie
                                • Jun 2010
                                • 281
                                • Enid, OK
                                Thanks, Nate, what about the 4-ways (in case of break-downs, which almost never happen, right!)?
                                Richard
                                '02 Honda VTX1800C
