Jardine 4 in1
  • gwh57
    • Feb 2007
    • 11
    • St.Louis Mo.
    Jardine 4 in1
    Hi All
    I'm having a problem with handle bars buzzing after installing Jardine 4 in 1 header. I checked to make sure pipes are not touching the frame anywhere. I also replaced the steel muffler hanger with a rubber one to vary little affect. Has any one else had this problem and if so how did you solve it ?
    I CAN'T HELP MY SELF I'M XJ CRAZY!!!
    3, 82 xj1100 maxims 2 road ready and 1 parts
    3, 81 xj750 secas 2 road ready 1 parts
    2, 81 xj650 maxims 1 road ready 1 parts
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    What exhaust did you have on before? Did you need to rejet? If you did rejet did you resync? I noticed a small vibration on the bars that went away after a sync.
    Ernie
    • gwh57
      • Feb 2007
      • 11
      • St.Louis Mo.
      Hay egsols
      This is a 1982 XJ1100J with 9000 actual miles. It had a factory exhaust that rotted apart. I did'nt need to rejet the bike it pulled good and hard with no cutting out or hesitation from 1,100 rpm all the way to 10,000 rpm in 1st., 2nd. and 3rd gear. I felt that was fast enough for me. Carbs. were sync and adjusted late last year. No adjustment was needed after the 4 in 1 was installed it ran the same as before.
        vibration
        I had a similar problem with the Mac 4-1 system on my 79 Special. I mounted the canister hanger to that rubber bushing to the rear of the rt. passenger peg. Wow what a terrible vibration. To fix this I found if I used a metal washer over the outside of this bracket, making the connection metal to metal, the vibration went away completely. First I figured the rubber would dampen the vibration but it turned out to be exactly the opposite. HTH.
          pic.
          Here a pic. of my fix.
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            My MAC 4 into 1 was also a metal to metal setup and the bike did not vibrate with that set up. Now on my restored 79 with the stock exhaust the bike does vibrate and that exhaust is completely rubber mounted.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • gwh57
              • Feb 2007
              • 11
              • St.Louis Mo.
              Hi agin
              When I get the stiches out of my hand and the weather warms up a bit. I will sure try the metal to metal mounting and let you guys know it turns out. Thanks for the help
              • gwh57
                • Feb 2007
                • 11
                • St.Louis Mo.
                Hi, All
                The metal to metal fix worked like a charm. There is less buzzing in the bars now than it was stock.
                THANKS FOR THE HELP!
                • DJinNH
                  • Mar 2008
                  • 854
                  • New Hampshire
                  Re: vibration
                  Phil, thanks for the tip. I've got a Jardine 4 into 1 set that I am about to put on my XS1100SG so your info should be very helpful.
                  Don
                  currently own;
                  1980 Yamaha XS1100 SG
                  2009 Yamaha Star Raider
                    vibration
                    No problem guys. Anytime. Glad I could help.
                    • gwh57
                      • Feb 2007
                      • 11
                      • St.Louis Mo.
                      Hi, All
                      The solid metal to metal mounting of the exhaust has stopped the vibration / buzzing in the handle bars and moved it to the right foot peg. After about 20 miles my foot is numb and my knee feels like I have a bad cramp. Is there anyone else that has or had this problem ? Any idea on how to fix this?
                      • dpotter58
                        • Aug 2004
                        • 1866
                        • Southern Maryland
                        No idea on the buzzing. I just installed a Jardine 4 into 1, black with chrome muffler and while the bike runs VERY well, I find the right turns get a little dicey when layed over...
                        Between a couple of scrapes at 60 or so in a turn and the looks of it, I'll be pulling it off and going back to stock this fall.
                        1980 LG
                        1981 LH
