Bike won't start
  • audijunky
    • Apr 2006
    • 707
    • VA
    Bike won't start
    Ok , between running and now all I did was the pickup wire fix. And It had previously been done by the PO but it was sh-tty so I redid it and used heat shrink. left plenty of slack for flexibility. If some how I did it wrong would this prevent it fron starting. I had also put the GSXR1100 carbs on. When I was trying to start it with those on I figured it was the carbs , so I put my old ones on and it still wont start, not even trying really. I checked for spark on cylinders 1,3,4 and it is there. Checked all the fuses, they are good. Any Ideas??
    Thanks for your replies.
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
  • randy
    • Dec 2003
    • 4521
    audi,
    Is it possible that you inadvertently swapped the pickups (1-4 and 2-3)?
    Reverse the spark plug leads to test my theory, move 2-3 to 1-4 and 1-4 to 2-3 and try to start it.
    • mro
      • 4276
      • Hayward, California
      And now for a "Totally Wasted" spark system
      mro
      BTW, might want to make but one serious mod or change at a time. Can help prevent premature balding due to head scratching
      • audijunky
        • Apr 2006
        • 707
        • VA
        I'll try that randy , thanks
        • audijunky
          • Apr 2006
          • 707
          • VA
          I guess there is a reason Randy has GURU status. You were spot on. I wired them backward. Runs good now. Can I leave the like that or should I rewire??
          Now I get to try these gsxr carbs A gain.
          Man I miss riding that beast been about 7 months.
          • randy
            • Dec 2003
            • 4521
            Glad it worked out. Don't ask me how I knew that!
            You can leave it that way and re-mark your plug wires so you don't have to remember what you did.
