Guru Question
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    Guru Question
    Anyone have a spare ignition switch laying around to measure the bolt holes center to center where it attaches to the upper triple tree (exactly in mm)? I need to know whether I need to buy another xs11 switch off Ebay or get the Hayabusa switch and modify the wire harness. I hope it's the former. The Hayabusa tree is 48mm Center to Center.....thanks
    MDRNF
    79F.....Not Stock
    Just measured spare from Special.
    Inside edge bolt hole to inside edge=42.00mm
    Outside edge bolt holes=54.0mm
    It seemed like it was 48mm center to center!
      • 8669
      I measured the bolt holes on a standard upper triple tree. Also 48 mm center to center.
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        Guru comes thru
        Looks like I will need a new xs11 switch. BTW what is the heighth of it from key surface to triple tree mount surface?
        MDRNF
        79F.....Not Stock
          • 8669
          I get 63mm from mounting surface to key slot. This is on a 79 standard.
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            Thanks
            I appreciate it. The Hayabusa tree ignition heighth is 60mm as well. So it looks like an entire Hayabusa front end will bolt on to the xs11 frame with just a custom 30x47 bearing....Amazing......thanks again
            MDRNF
            79F.....Not Stock
            • bwilding_2000
              • 50
              • UTAH-SLC
              Your Hayabusa moda sounds sweet!
              So, have you got a picture of this front end swap? How far along is the process? I have been thinking about doing the same thing, a Hayabusa front end, but I don't know if I need to buy a special bearing or have someting machined. Any pointers?
              Thanks!
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                Short and simple
                Get a 30x48x15 tapered bearing and turn down the outer diameter of the RACE by 1mm. It takes a special lathe offset grinding attachment to do this because of the race hardness. Good machine shops have these and will probably charge 20-30 bucks for the service......Don't waste your time trying to find a 30x47x15 tapered bearing....they DO NOT exist......
                MDRNF
                79F.....Not Stock
