Progressive Fork Springs?
  • Da-Bubble
    • Jun 2006
    • 353
    • Oklahoma City, OK
    Hello,
    I have had a blast putting over 400 miles on the Mad Mosquito since it's completion, but the suspension is about to shake out my fillings. I am happy with the rear springs but the front is super rough. Where do I buy Progressive fork springs? Their website says the local Harley dealer is the only place and I can't find any on eBay.
    Thanks
    P.S. Got a set of 2000 ZRX 1100 carbs to put on too!!!
    1979 XS11 Special (slightly modified)
    dubbed the "Mad Mosquito"
    MikesXs Pod Filters
    MikesXs 35k Coils
    8mm plug wires
    42.5 Pilots 142.5 Mains
    (Carb tune by GNEPIG Performance)
    Kerker 4-into-1
    Shaved emblems
    Progressive frt springs lowered 1.5"
    Progressive 11.5" rear shocks
    Harley Dyna rear fender chopped
    Custm side mt tag (apparently illegal)
    Custom Dual Headlights
    Lots of time and hard work.
    Bikebandit has them for $74. I just checked their site for the info.
    Wildkat bought me some for Xmas, but I haven't had a chance to install them yet.
      Check out BikeBandit.com:
      Here's the Aftermarket/street/suspension/progressive springs/yamaha page
      Name: Progressive Suspension Fork Springs (Yamaha XS1100 Special 1979-1981)
      Price: $74.65 Your Price!
      $82.95 MSRP
      Brand: Progressive Suspension
      Note Spacers are NOT included. They may easily be fabricated from aluminum or PVC pipe.
      They talk about a spacer, because the Specials use longer tubes, but they(progressive) only make one size spring for the 1100's, and so you put in a ~4in spacer to take up the slack!
      WOW, Stereo replies! I, too, checked their availability, that's how John beat me to the punch!
        followup questions?
        Hey Da-bubble,
        I got to thinkin' a little. What weight fork oil did you use?
        And do you have any air in the front forks for the preload?
        If you are using a 10-15 wt fork oil, you might want to try some 5 wt first??
        • Hobbit
          • Nov 2002
          • 372
          • Jacksonville, FL
          Springs
          I've had the Progressives for several years now and I like the way the work.
          Walt
          80 XS11s - "Landshark"
          79 XS11s
          03 Valkyrie
          80 XS Midnight Special - Freebee 1
          78 Honda CB125C - Freebee 2
          81 Suzuki 850L - Freebee 3
          • Da-Bubble
            • Jun 2006
            • 353
            • Oklahoma City, OK
            T.C. and John,
            I used whatever weight that Clymers called for. I think my problem is that I used solid spacers stacked on top of what progressive calls the "top out springs". This spacer sits over the dampening rod where the small holes allow oil to squirt thru. In the Progressive kit, they include two sets of top out springs for 1 or 2 inch lowering. The springs wouldn't interfere with the flow of oil like my spacers do. That coupled with a 300lb rider and 29 yr old springs and I think I can justify some progressives.
            Thanks for the advice. Any idea what shipping would run? A guy on ebay has every kit under the sun listed including FJ and Vmax's. I thought about emailing to see if he can list one for an XS his are $85 shipped.
            Thanks,
            Scott
            MikesXs Pod Filters
            MikesXs 35k Coils
            8mm plug wires
            Kerker 4-into-1
            Shaved emblems
              Originally posted by Da-Bubble
              T.C. and John,
              Thanks,
              Scott
              Geez, do I/we have to do EVERYTHING!
              Bike Bandit says:
              Shipping Options / International Shipping
              In the first step of the checkout process, we'll ask which shipping method you'd prefer. BikeBandit.com offers a choice of two shipping methods for most orders: Ground and Express. For orders under $20.00 in value, we provide super-discounted ground shipping for a flat fee of just $5.95. For larger orders, our Ground shipping charge is a flat $7.95. BikeBandit.com charges a flat $24.95 fee for Express shipping. Orders shipped Ground may be sent by FedEx or USPS. Orders sent Express will be shipped using a premium service such as FedEx 2nd Day Service or USPS Priority Mail. Large or heavy orders may only be shipped Ground. BikeBandit.com may ask for authorization for additional shipping charges for oversized or heavy orders.
              • SFerinTEXAS
                • Jun 2006
                • 876
                Just bought a set from Motorcycle Accessory Warehouse .Total cost including shipping was 66.79 . It even included a piece of PVC tube for the 3.5" spacers . Used a small tubing cutter to make a perfect score in the pvc and finished thru with a saw.
                79SF
                XJ11
                78E
                • Da-Bubble
                  • Jun 2006
                  • 353
                  • Oklahoma City, OK
                  Thanks! Just ordered a set for $66.79. Can't wait!
                  MikesXs Pod Filters
                  MikesXs 35k Coils
                  8mm plug wires
                  Kerker 4-into-1
                  Shaved emblems
                  • morticiaann
                    • Apr 2003
                    • 90
                    • Long Beach, CA
                    I read a tech article on what is wrong with the xs11. It said, "handling is bad and the xs11 needs a fork brace & heavier front springs". Because of this I cut the spacers to 4". I could barely get the fork caps to screw in [I couldn't get the forks screwed back together with the spacer cut any longer]. I used my cutting tool for auto body and other steel to cut the spacer. The ride is exceptional now and the front end stays up. I used 15w oil.
                    [IMG]http://michaelwilliamandersen.ga[/IMG]
