Battery
  • scappod
    • Mar 2005
    • 233
    • Bremerton Washington
    Battery
    Hey Guys and Gals
    Is it possible to run an xs 650 sized battery in our bikes?? I have a box that will fit it ready to go into my frame if I can use it.
    I am going through my wiring and ridding myself of things I don't need like the reserve lighting unit and the self canceller and some other things and I wanna reduce the battery size... Can it be done?
    Ego Sum Meus Frater Custodis...
  • bigb9582
    • Jun 2007
    • 118
    • fayetteville, PA
    i ran mine for a while on a small battery out of a old three wheeler, till i finaly bought the correct size battery. i had to use a block of wood to keep it from moving but besides that i didnt have any issues with starting or anything.
    as long as its big enough to start and run the machine, i wouldnt see any problems runnin a smaller battery. a 650 battery cant be that much smaller.
    79 xs1100f- standard- $50.00 runner
      Hey Barry,
      Our battery is rated at 20 AmpHours, the 650 is only 14 amp hours. The 11 is rated at 260 cca, the 650 is 190 cca. So... the 650 battery might not have enough OOMPH when it's cold to be able to turn over and have enough power left to fire the TCI??
      Once the bike is running, IT's mostly running off of the ALT, so the main thing is being able to turn over the motor adequately and have enough reserve power to also provide the 10.5 volts minimum to fire the TCI! YMMV?
      Do you want to risk being stranded?
      • scappod
        • Mar 2005
        • 233
        battery
        Dont wanna get stranded,
        I was wondering if I could get the same cranking amps from a smaller battery. I thought with todays battery technologies it would be just a matter of finding one...
          • 7830
          Look at the new "gel" battery. They may give you the cranking amps you need, in the smaller package. JAT
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            small battery
            hey scap, I am using the Odyssey pc545. Does a great jod of cranking and measures 3x5x7, smaller than stock xs11 battery and cranks just as hard.
            MDRNF
            79F.....Not Stock
            • scappod
              • Mar 2005
              • 233
              HEy thanks guys,
              I will look at the Odyssey and the gel to see whats what
              I will let you know what I go with
              • mason79
                • Mar 2006
                • 1359
                • los angeles, ca
                Re: small battery
                hey xschop, i'm in the market myself, how did you bolt it down? did you have to fabricate a holder? thanks
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  strapped
                  yeah mason, it goes right between the rear hangers (7") if you chop them down shorter. Scappod is also building a chaindrive bike and doing some other custom stuff...
                  MDRNF
                  79F.....Not Stock
