XS11 SG Conversion
  • Danger-russ
    • Feb 2008
    • 1
    • Huntington Beach, CA
    XS11 SG Conversion
    Has anyone tried this before? Can you convert an SG to a G? Just bought a 1980 XS Eleven SG (for $100...so couldn't pass it up) but prefer the simple beauty of the Standard G. Is it possible to do a conversion?
    Thank you.
    imdangerruss
    1980 XS Eleven SG (Project)
    1997 Kawasaki Vulcan 1500 (Main ride)
    1986 Suzuki Cavalcade 1400 (P.O.S.)
    Anything is possible. You can fit a lot of the "G" parts onto the "SG". The biggest thing is the footpeg mounts, I don't know if the standards will bolt up to the frame. I know the tank will fit, and if you can find the standard front forks and trees, they will also swap out.
    Welcome to the site, and don't forget to go to the home page, XS11.com, and search the tech tips from there. You will probably find the answers to most of your questions.
    • mro
      • 4276
      • Hayward, California
      Frame, foot peg bracket, triple tree, forks, rear wheel, rear brake, gages are just the most obvious differences...
      I might have a rolling F frame complete with brakes but have not looked at it for a while. If interested PM me and I'll take a look.
      mro
      Welcome to XSland
      • Lamric
        XStremely XSive(Deceased)
        • 410
        • Kenley, Surrey, England
        Danger-russ, this will help you work out what would need to be changed ...
        This website allows you to see what parts from one model of XS1100 are used on another.
        Looks like this
        Also has over 2,000 photographs of XS1100 parts.
        Brian
        XS1100 LG "Mr T", SG "ICBM" & FJ1200
        Check out the XS Part Number Finder
        Be not stingy in what costs nothing as courtesy, counsel and countenance.
        • Dennyz
          • 1151
          • Olympia, Washington
          To get a 'G' seat to fit properly, you will also have to relocate the Ignition Control box. This will require the rear inner fender, hinged fender mount and rear fender. There may be a problem with the SG's wiring harness being long enough to reach the new (rear) location.
          DZ
          Vyger, 'F'
          "The Special", 'SF'
          '08 FJR1300
