XJ shock question
    XJ shock question
    I have been cleaning up mu XJ rear shocks off of the bike. They have been turned every which way and upside down for an extended period. I have no knowledge of the guts of the shocks. Is it possible for the oil to get up into the air line that joins the two? If so, what do you suggest to be the best way to assure each shock has the right amount of oil? I was thinking about turning them both upside down to sit a while to even out, then hang them by the center of the hose.
    If the oil can't get into the air lines, it's a mute point.
    Thanks.
  • boyat68
    • Oct 2007
    • 358
    • Virginia
    trbig:
    read http://www.hotbikeweb.com/tech/0612_...cks/index.html
    It will give you a picture cut away of a typical gas/oil shock. The unit is sealed and has a valving system that allows the oil to seep by when pressure is applied. Turning them upside down can't hurt anything as just shipping and handling would cause a problem if this was so.
    • lsippell
      • Sep 2003
      • 216
      • Mayflower, Arkansas
      The way the XJ air shocks are built the oil can and will get into the crossover hose it you turn them upside down. It can even run from one shock into the other.The manual says, 'When storing away the suspension, be careful not to place it in an inverted position'
      Take the hose and fitting off and measure the depth of the oil (2.95 in. down from top). It uses G-5 (SAE 5W).
      I overfilled mine, then used a price of heat shrink tubing that I slipped a small nut over 2.95 in. from end, slid it down into the shock and used a bulb syringe so suck out the excess.
      Louis
      "There is no mechanical problem so difficult that it cannot be overcome by
      brute strength and ignorance" And possibly some Mouse Milk!
      '82 XJ1100J
      LED Dir and running lights
      LED Tail/Brake lights (4) one flashing
      Modulated H/L
      PIAA Driving lights
      YICS Eliminated
      750 FD
      Yamaha Factory X-1 Fairing and Luggage
        &*!@^#&%!%#!@#)%!!!! (Edited for family content... )
        I already installed them back on the bike too... Sounds like a good plan, Louis. Thanks.
