Seems fast....
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    Seems fast....
    I have had experience with a few speedo's for the xs11's and I have found that they are all showing about 5 mph faster than actual speed. I have checked them with radar so I know they are fast and on a trip I checked the odo with the mileage posts and that is incorrect also. In 7 miles it was off .2 mi, probably register 105 mi for actual 100 mi. I wonder if anyone else has noticed the same thing? It was Mason that first brought it to my attention way back when.......
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    • 7818
    I've seen the same on ALL the XS1100 I've owned. Daily ride is on the second speedometer, and it seems a little farther off than the original. I think it's still within the 5% range.
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      "Trippin' on speed..."
      I can't recall if it was the Kawasaki tech line, or the Triumph guy... But I believe I was told once that legally, they can be off by 20%.
      I don't know... I'd have to do the math on this one....
      I'm sure that when they build bikes, they use the same speedo gear set up at the wheel... just change around the speedometer dials depending on where it's sold.. Kilometers vs Miles.
      That might explain why bikes are usually off.
      Who knows... The kilo ones may be right on.
      Now then.. that bring up another question.
      As my speedo has miles in big white letters on the outside and kilometers in little letters on the inside... do the european ones have big kilos on the outside and little miles on the inside?
      Hello..?
      European riders...?
      Englanders...?
      Aussies...?
      What cha got?
      • AlanB
        • Oct 2006
        • 705
        • Scotland
        Hi Prom,
        UK uses miles too....... Although my bike is from Colorado...LOL!
        AlanB
        If it ain't broke, modify it!
          • 8893
          79sf - reads 56mph, actual speed 60mph
          79f- reads 59mph, actual speed 60mph.
          Just got speeding ticket today on 79f, speedo very accurate on that bike.
          • red bandit
            • 970
            • central michigan
            Mine reads 59/60 when actual is 55.
            79 SF parts bike.
            • planedick
              • Mar 2005
              • 2068
              Kilo speedo....
              I had a kilometer speedo on the '79, in fact it's still on it and it is also fast. Lots of those signs with radar around here and checking one's speedo is easy.
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
                speedo
                Must of got lucky..........with the Metzler 3:25x19/ME33 speedo IS 60 at 60, and is original speedo.
                  • 8061
                  100/90-19 is a little smaller than the original tire. It contributes to a fast needle. My XS650 behaves exactly the same way.
                  • Dragon Tamer
                    XStremely XSive(Deceased)
                    • Sep 2006
                    • 426
                    • Half way between Chili and Winter Wisconsin.
                    The Dragons speedo is spot on after you have held a given speed for several seconds. If you are accelerating or decelerating then it lags behind for a short time. I have lubed it a couple of times and it did not seem to change anything. As I usually have the GPS up and running I can use that if I am worried about the actual speed, if not I just go with the flow.
                    The Old Tamer
                    _________________________
                    1979 XS1100SF (The Fire Dragon)
                    1982 650 Maxim (The Little Dragon)
                    another '82 650 Maxim (Parts Dragon)
                    1981 XS1100SH (The Black Dragon)
                    If there are more than three bolts holding it on there, it is most likely a very important part!
                    • Lamric
                      • 410
                      • Kenley, Surrey, England
                      Prom,
                      This is the European 2H9 model Speedo, makes the bike look really fast
                      Just need to scrape off that little 'k' at the bottom of the dial.
                      Brian
                      XS1100 LG "Mr T", SG "ICBM" & FJ1200
                      Check out the XS Part Number Finder
                      Be not stingy in what costs nothing as courtesy, counsel and countenance.
                      • mro
                        • 4276
                        • Hayward, California
                        Thats the way European gov's make there driving/riding public feel like there really getting somewhere. Do only 120 KPH on a CA freeway will get you run over by a cage
                        mro
                        • xsilerating
                          • Dec 2006
                          • 431
                          • Eastern Ontario, Canada
                          Prom asks....
                          Hello..?
                          European riders...?
                          Englanders...?
                          Aussies...?
                          What cha got?
                          Canadian models are the reverse... Kilometers in large white numerals on the outside with MPH in small numerals on the inside.
                          1980 XS11 LG (Diablo)
                          1980 XS11 G (Bagger)
                          1978 XS11 G (White Knight)
                          1978 XS11 G (Skeleton)
                          2016 SS (S.S. Flyer)
                          • prometheus578
                            • Aug 2004
                            • 4012
                            • Olympia , Wa.
                            Thanks for the info, gentlemen.
                            • Miti-Babe
                              • Oct 2007
                              • 42
                              • Glasgow, Scotland
                              Prom
                              I think it depends on what model you have....
                              My 5K7 (UK Sport model) reads 0 - 160 mph and doesn't have kph on it at all... I've seen UK Std XS11's (square clocks) with 0 - 160 mph on the outside of the scale and 0 - 220 (I think) kph in smaller text on the inside...
                              Alan
                              That don't count... It's not a UK or Euro model, is it..?
                              Miti
                              One of those terribly nice chaps on XS1100.com
                              • XS1100S (5K7) '83 "Sport #1 - Trike Donor"
                              • XS1100S (5K7) '85 "Sport #2"
                              • XS1100LG (4W1) '80 "A Tribute to Brian"
                              • Hesketh V1000 '82 - Dream Realised...
