sticky speedo...
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    sticky speedo...
    i just swaped the stock 160 speedo back in that the po took out. it will get up to speed but it's a little slow getting there??? and when i slow down it is still saying i am going much faster??? the eventually it drops. i sparyed wd 40 on the cable before i reinstalled it and it worked fine with the 85 mph speedo . should i take it back apart and lube the 160 up somewhere? also upon replacing the top bulb in the tach i think i knocked a wire loose because the tach is now twitchy some. any ideas?
    chris
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
  • corey
    • Mar 2005
    • 208
    • Dexter, MO
    Mine does the same thing every once in a while. I haven't looked into it much since it is so rare and random, but mine is often associated with a whinning noise coming from the speedy. I assumed it was from the cable not being notched up properly/something being stripped.
    Lubing it wouldn't hurt, though...
    Corey J. Bennett
    '79 XS1100SF
      • 7819
      I would pull the speedo, and lube it buy turning it upside down, and pouring a little LIGHT oil in. Just a few drops of 3in1 oil will probably work well. Let it set upside down for about 1/2 hour, then reinstall it. If it gets to bad, you WILL break speedo cables!! DAMHIK.
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        Mine did that when I got it running. Replaced the speedo drive cable and al was well.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          well i thought that might do it but the thing worked the day before with the 85 mph speedo and the odometer is right on the money. i held her perfectly at 60 mph and looked at the od. and looked at the mile marker and at exactly 1 mile it was 1 mile ahead on the odometer so i think it's working but the speedo needs lube... would wd 40 be ok in there?
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          led's gallore...
          renthal bars
          vmax tensioner
          Rifle fairing
          • mro
            • Oct 2005
            • 4276
            • Hayward, California
            wd 40
            Has it's uses,
            but drys up and disapears in a short time.
            mro
            • oseaghdha
              • Aug 2006
              • 1075
              • N43.02.5,W88.14.2
              Had the same problem
              Bike had sat for a looooong time.
              The speedo started howling when I first got it out for a shake down. I thought the top end was seizing up.
              It would also happily tell me I was going fifty mph, after I stopped at the light.
              Anyway, had to dissassemble the speedo and put some light oil in the works.
              XS1100SF
              XS1100F
              • John
                • 5117
                This might help
