zrx carbs on my xj...
    • 6765
    Originally posted by ae7f
    Those are some pretty carbs. They look as new and unmolested as my ZRX carbs....
    Bid away.
    Thanks Ben...good advice is greatly appreciated...I am currently bidding on them....
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
    • yamahansolo
      • Aug 2007
      • 1113
      • jawga
      i can't remember if i asked or if it was already posted somewhere... i have 2002 carbs so i don't know what the stock jets are for that. and also what would anyone recomend to start out with for jets?
      right now i just open the throttle up and it dies and backfires right away... but i may have some crud up in the mufflers somewhere unfortuanitly???
      79 xs11 standard
      8mm msd wires
      tkat fork brace...
      Fox shocks...
      mikes650 front fender
      led's gallore...
      renthal bars
      gold valve emulators
      vmax tensioner
      Rifle fairing
      • renegade_xs11g
        • 462
        • Mid-Michigan
        nope, I'll bet that your carbs aren't sync'd
        does it idle OK?
        will it climb if left alone?
        does it die every time you hit the throttle?
        even if you just touch it, just a little?
        or will it climb a little then die? alot then die?
        My Photo Bucket
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          well i think there's crud in the exhaust because there is smoke coming out from a hole in the front left exhaust sopmewhere. also the carbs came off a running bike and i havent adjusted anything yet. i think the jets may need to be smaller since this was for a 1200 and mine is 1100 also i was not sure what to do with the two hoses that come off the top of the carbs, i need to find the zrx keihn breakdown so i can see where the hoses go. it has some little tips on the back of the carbs above each opening 1 was capped off and the other 3 were not. so i capped them. which hoses are supposed to make the slides go up when you open the throttle or do they do that on there own?
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          led's gallore...
          renthal bars
          vmax tensioner
          Rifle fairing
