zrx carbs on my xj...
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    ok it looks like the swap will be pretty easy since the xj has a choke already like the kawa. the mount for the throttle seems to be pretty much in the same spot.
    now for the kicker... i know it's supposed to squeeze right into the manifolds but mine may be too dry rotted??? they are very hard and not flexible. i got them lubed up a bit and i only worked at it for a second because i have to go somewhere here in a momento. do ya;; think they will fit or am i going to have to get new boots? hhmmmmm they are kinda pricey but i am going to try to soften them up.
    also i think i need to heat them too because the bike is in my garage and it's about 40 in there if i get them good and hot they should stretch better theoretically right?
    i can't wait it'll be running soon.
    the carbs are in pretty good shape especially for 60 bucks! only problem was when he shipped it he didn't wrap the plug for the tps so it busted??? i'll have to get on to him. little does he know i don't need the tps. i might fab a block off plate and take it off if i can.
    also for the xj does anyone recomend what to do with the two vac line coming off the carb? i am planning on putting the one from carb two onto the manifold #2 and the one between carb 3-4 i was planning on putting onto manifold 3 or 4??? also it didn't have caps on 1 and 4 from the back of the carbs should i cap those off?
    any tips will be greatly apreciated! also i have already done several searches and am compiling my info for a good read so i can tackle this the right way the first time!
    chris
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
  • Shuriken
    • 1093
    • Southwest USA
    The ZRX carbs I have on my bike installed really quite easily. Have you used WD-40 or something to allow smoother assembly?
    Ben
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
    • yamahansolo
      • Aug 2007
      • 1113
      • jawga
      i did but i didn't get the boots warmed up it is very cold in there! so they aren't very flexible. i'll lubeem up more later and warm them up and hopefully have them on three this weekend! thanks for the link!!!
      79 xs11 standard
      8mm msd wires
      tkat fork brace...
      Fox shocks...
      led's gallore...
      renthal bars
      vmax tensioner
      Rifle fairing
      • yamahansolo
        • Aug 2007
        • 1113
        • jawga
        hey any body have any tips of what i can do with the two bowl breather tubes if i decide to run pods? the stock airbox is pretty trashed because of bugs and stuff getting into it while it was on a box... ???
        79 xs11 standard
        8mm msd wires
        tkat fork brace...
        Fox shocks...
        led's gallore...
        renthal bars
        vmax tensioner
        Rifle fairing
          You can run the hoses up to a "T" fitting, then to a small fuel filter up under the tank. This lets them keep breathing, and keeps dust and small bugs out of the hoses.
          • airflo
            • Jun 2007
            • 3
            • edinburgh scotland
            hi there a quick and easy fix to soften up inlet manifold rubbers is to boil them in jello you know the stuff that comes in a solid block ,this stuff is gliserine err glister err what the heck it softens them up hope this helps cheers dougie
            • yamahansolo
              • Aug 2007
              • 1113
              • jawga
              thanks fopr the tips.. i gotem on last night. plus i had to take them right back off becuase i forgot to hook up the throttle cable
              but they were easier the second time!
              79 xs11 standard
              8mm msd wires
              tkat fork brace...
              Fox shocks...
              led's gallore...
              renthal bars
              vmax tensioner
              Rifle fairing
              • somesuch
                • Jun 2007
                • 145
                • San Jose CA
                So how does it run? C'mon we all want to know
                --Nick
                • yamahansolo
                  • Aug 2007
                  • 1113
                  • jawga
                  it's a project bike... no where near running yet. unfortuanilty! i still have the brakes to do and then some cosmetic stuff. and it'll need new tires among other things
                  79 xs11 standard
                  8mm msd wires
                  tkat fork brace...
                  Fox shocks...
                  led's gallore...
                  renthal bars
                  vmax tensioner
                  Rifle fairing
                    • 2117
                    I also own a ZRX and know someone who has a set of carbs for under $200.00.
                    • yamahansolo
                      • Aug 2007
                      • 1113
                      • jawga
                      well i got some stuff together tonight and cranked her up! it sounded ok but i don't have any filters hooked up and the bike probobly needs to be tuned but like i said a lot of work left to go unfortuanitly!
                      79 xs11 standard
                      8mm msd wires
                      tkat fork brace...
                      Fox shocks...
                      led's gallore...
                      renthal bars
                      vmax tensioner
                      Rifle fairing
                        • 6765
                        yamahansolo...I am interested in retrofitting ZRX carbs to my '82 XJ1100...a couple of questions...1)what year bike did the carbs come off of?2)were all ZRXs' 36mm size?....on ebay I found what i think might be a good deal but I want some opinions before I commit...the auction # is 150211105399...let me know pls what you think...Thanks
                        2005 Honda SilverWing 600
                        2018 Honda PC-Xpress 150
                        • Shuriken
                          • 1093
                          • Southwest USA
                          madmax-im:
                          Check out my post on this page for more info:
                          May answer your questions.
                          Formerly:
                          1982 XS650
                          1980 XS1100g
                          1979 XS1100sf
                          1978 XS1100e donor
                            • 6765
                            Originally posted by ae7f
                            madmax-im:
                            Ben ...I Thankyou Sir...you have managed to answer my questions in short order...BTW my name is Ben too!The carbs I found are off the 2004 ZRX 1200 so now that i know they will work I am goona do some bidding...does this carbset look complete to you?
                            • Shuriken
                              • 1093
                              • Southwest USA
                              Those are some pretty carbs. They look as new and unmolested as my ZRX carbs....
                              Bid away.
                              Formerly:
                              1982 XS650
                              1980 XS1100g
                              1979 XS1100sf
                              1978 XS1100e donor
