'78 Cycles article on the XS1100 & mpg
  • FSCGunslinger
    • 200
    • Hedgesville, WV
    I've been reading over the old article in the '78 issue of Cycles magazine that Dragon Tamer sent me about the XS1100. In the stats section is says that this beast got 44.7 mpg!!! Can someone explain that to me since ours now-a-days only get around 32 or thereabouts? I'd surely like to know!
    "I said I never had much use for [a pistol], never said I didn't know how to use one."
    '82 Maxim XJ1100J (Maroon) - "Organ Donor" - Parts bike
    '82 Maxim XJ1100J (Black) - "Outrider" - Dynojet Stage 1 kit, Kerker 4-1 exhaust, AGM battery, Mikes XS coils, small inline fuel filters, Dunlopp Elite-3 tires
    '06 Star Warrior (Custom Gadsden Flag Theme) - "ΜΟΛΩΝ ΛΑΒΕ" - Sissy bar w/ luggage rack, 4" risers, braided stainless steel cables and brake line; Mods on deck: new exhaust, new seat
  • stoked
    • Oct 2007
    • 149
    • Broken Arrow, OK
    My best guess would be they didn't calculate it correctly. The lower speed limits back then could also be a factor. Going 55 mph does significantly reduce your drag from wind and lower your rpms quite a bit compared to 70 mph average. But at best I would think that would get you around 38 to 40 mpg.
    79 XS11 special
      • 7831
      I used to get 45 MPG ALL the time with my first XS1100. It was a '78, serial number 000254. Best MPG was 53, two up on a ride with about 15 bikes. worst was about 39, WOT almost the complete tank.
      The fuel we have now is different, and DOES NOT pack the same BTU per gallon. That is the biggest single reason for the MPG difference. I was only able to get 38 MPG with my present bike, before the final drive switch. I now get about 42 MPG on my commute.
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        Could it also be that gasoline was different then? There are things added to gas now to make it "cleaner".
        I know gas I buy from AM/PM costs less but my fuel mileage is less with that gas.
        Just a thought.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
        • xswilly
          • Jul 2003
          • 462
          • Hollis, maine
          We had leaded gas back then, more lubrication
          i think unleaded gas makes the engine run hotter
          i also had mine back in 78 and did get 40 - 45
          when i ran around the speed limit
          but when you let it loose the mpg droped into the 30- 35 range
          http://home.securespeed.us/~xswilly/
          79F Parts
          80G Parts
          75 DT 400B enduro
          • FSCGunslinger
            • 200
            • Hedgesville, WV
            Hh... interesting about the gas differences. So what should I realistically be looking to get for mpg out of my XJ11 that's in great running condition? I hear they are suppose to get better mileage than XS's. Is this true?
            • boyat68
              • Oct 2007
              • 358
              • Virginia
              If you apply physics to the question, and assume that the 10% ethanol blended has less than 75% of the power of standard gasoline coupled with the fact that the original figure was derived from labratory conditions, (Cycle running on a dynometer in a closed enviroment running leaded gasoline), then it is any wonder that you will get 30 miles to a gallon.
              • stoked
                • Oct 2007
                • 149
                • Broken Arrow, OK
                Wow, you learn something new every day. I had no idea gas had become that ineffecient. I wonder if that's why quater mile times seam a little quicker back then also.
                79 XS11 special
                • erithanis
                  • Dec 2007
                  • 89
                  • Sunnyvale, CA 94089
                  :BLINK: I get 40-45 right now. I haven't tuned the engine at all since I got it. Not sure why your poor beasts are dragging.
                  Looking for an XS
                  79 XS1100SF (RIP)
                  - stock standard headers(stupid PO), slip-on after-market mufflers.
                  - after-market rear shocks (PO installed)
                  - no airbox, POD filters
                  Misery remembered is ADVENTURE!
                  • egsols
                    • Jan 2006
                    • 1090
                    • Barrie, Ontario, Canada
                    Mine was running good, mileage not great but after I synced the carbs the mileage went way way up!!
                    Ernie
                    • stoked
                      • Oct 2007
                      • 149
                      • Broken Arrow, OK
                      Hmm, interesting. This may be the thing that finally gets me to do that.
                      79 XS11 special
                      • Ken Talbot
                        • 4251
                        • Revelstoke, BC
                        For the longest time, Tsunami, in full dress form, averaged around 30 mpg (US gallon), even with a fresh sync and colortune. But, the plugs were always black. I dropped the floats by 2mm in each bowl, and the plugs cleaned up, and the mileage came up to a consistent 40 mpg. As before, this depends on having a good colortune and sync job, and taking it easy on the right hand. 44.7 should not be impossible for a nekkid bike in good tune.
                        YMMV
                        Ken Talbot
                          While cruising to John and Wildkat's in Texas, at the speed limit of 70mph, I get 35-37mpg. At 80-85, I get a little better than 40mpg?? Explain that one! So guess how fast I usually ride?? lol.
                          Headwinds/tailwinds will change things up by several miles a gallon though. I've had a 10mpg difference sometimes between going somewhere and returning in a strong wind.
                          • mro
                            • Oct 2005
                            • 4276
                            • Hayward, California
                            Cruising 45/55 the G gets 40+ mpg.
                            Around town, 32/36 mpg
                            Specials getting 32 to 38 mpg
                            Have been contemplating the final drive mod for one of the specials.
                            mro
                            • Squatch
                              • Mar 2012
                              • 17
                              • Kuwait
                              so lets say i want to go on an insane trip across country, how would i get my ileae up on my special, i mean whats the difference between the special and the regular, i know about the 55 mph golden zone with most vehcle, but what if i want to go faster, can i tune my machine for better milage at 65-70?
                              an what am i looking at on mpg for my 79 special... any mods that aren't too serious (transmissions freak me out...) or am I just stuck with a sub 40 mpg bike...
                              also how hard is the final drive mod to do...
                              I'm trying to get the best gas mileage out of my baby for a long ride (roughly 4000 mi) and I want to save money...
                              0
