'78 Cycles article on the XS1100 & mpg
    Those who have done it will tell you the FD swap is easy. I know some guys who went to Alaska last year all riding the same bike. The V-Max, which is another gas guzzler. Before the trip, all of the bikes were swapped to Euro final drive to extend the range. After the trip, the FDs were swapped back. It can't be too tough.
    • jimbyjimb
      • Feb 2010
      • 263
      • Seattle
      My 80 SG with XJ pipes usually does 33-35 on the interstate, between 4 and 5k RPM. Best I ever got was 38 cruising between 3 and 4k RPM on country highways. This was with the vacuum advance removed. I expect something a little better now that it's hooked back up.
      1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
      2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
      1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
      1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay.
