I bought new carb boots off e-bay and they came with gaskets. The ones on there at the moment (original I'm sure) don't appear to have gaskets so:
Should I use them or not?
Si Parker
'81 XS1100H
Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
The gaskets were made and added to the system for the XJ11's! The earlier models have a layer of rubber that meets with the head, but it gets old/dry/cracked and a place for a leak!
JOHN also posted a while back about some thermostat gaskets from a car that are essentially a bolt on match, for those wanting to use gaskets after they work on theirs!
I also prefer to use a non hardening gasket sealant like Yamabond or Permatex that can be around fuel and heat!
79SF "The Teacher" . . .basket case! History shows again and again,
I put some of the Ford 2.3 gaskets on my very old carb boots and they solved a leak that I chased around for awhile. The 78/79's have sort of an O ring type thingy (thats a technical term) molded into the mating surface. It cracked and leaked. The gaskets solved the prob. Cheap fix and worth a try.
Mike Giroir
79 XS-1100 Special
For the current XS11 I bought all new manifolds, but for one of the other ones that I had years ago, I just took a Dremel with a short 1/8" carbide ball end tip and holding my thumb inside the manifold sort of spun the manifold around my thumb. This hold on the Dremel/manifold is very steady and it is easy to make a nice grove in the manifold to accept suitable O-ring. Worked very well for many years, and you can re-place O-rings from then on.
