Crank & Conrod bearings
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    That's interesting .. I would have guessed that they would have set things up by strength of metals involved so that the bearings took the majority of the wear.
    So what that thread says is that the numbers are only good for assembling a NEW engine on the factory floor?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • 79XS11F
      • 3563
      I took some photos for those who have not seen some of this stuff other then in a manual or don't have a manual ..yet.
      The main crank casings numbers are on the under side of the engine mounting lugs and look like this.
      1978 XS500E
      1981 Suzuki GS1100
      • 79XS11F
        • 3563
        This IS NOT the Con Rod cap numbers ...
        This IS the Con Rod cap numbers ...
        1978 XS500E
        1981 Suzuki GS1100
        • 79XS11F
          • 3563
          This is what the crank shaft grouped numbers look like. They are on the left hand counter balancer ...
          1978 XS500E
          1981 Suzuki GS1100
          • 79XS11F
            • 3563
            A fair amount of floor or bench space is needed for a job like this and as you can see I really don't have enough space. If you tackle a job like this for the first time BE NEATER and have MORE space ....
            Rob
            1978 XS500E
            1981 Suzuki GS1100
            • 79XS11F
              • 3563
              WOW !!!
              WOW ... I'm glad I opted to do this job because the bearings do not look nice at all. That side play that I was concerned and asked about in a different thread is almost completely gone with the new bearings in place. The crank now only moves sideways enough to "just" be able to detect the movement.
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • Shappers
                • Sep 2006
                • 158
                • Helsinki, Finland
                Which shells did you go with in the end? Did you go by the numbers or just fit the thickest ones in?
                '84 Sport
                • 79XS11F
                  • 3563
                  I went with the factory recommendations. The bearings are much softer then the crank pins and should therefore take the bulk of the wear. I'm sure i will be in good shape with the factory selections and will not have to worry about being too tight. I'll just break her in again when she hits the road.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                    I like to do wheelies and fly by the police station at 100mph+ on the same night I do my bearings... lol. (It was all either Wildkat's or Hobbyman's fault)
                    • 79XS11F
                      • 3563
                      LOL will there is something to be said for 'finding out what you got" right away LOL LOL
                      I'm sure they will be fine BUT .. and there's always a BUT ... with the dollars and time spent on the top end I will break her in as suggested by Yamaha.
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
