Opinions ... Can I change out the crank and conrod bearings by just using the correct color code replacements without the pre replacement and after replacement clearance testing? If plasti-gage tests were to indicate that the correct color replacements were a little tight what happens then? ...
Rob
Rob
And that should leave you with a "new" bottom end after you replace the starter clutch, trans bearings/shift forks/undercut the gears, and maybe I am forgetting a thing or two
