Oil Cooler Removal
  • MrWheelie
    • Dec 2007
    • 92
    • Dallas Texas
    Oil Cooler Removal
    I removed my aftermarket oil cooler, can I just plug the two holes and run it?
    1978 XS-Eleven
  • AlanB
    • Oct 2006
    • 705
    • Scotland
    Hi Mr Wheelie,
    Where are the take-offs on the engine?
    They are usually on a sandwich plate between the bottom of the motor and the oil filter. If it is there, just drop off the filter and remove the plate. Filter will then fit back up to the bottom of the motor, as it did from the factory.
    AlanB
    If it ain't broke, modify it!
    • MrWheelie
      • Dec 2007
      • 92
      • Dallas Texas
      Originally posted by AlanB
      Hi Mr Wheelie,
      AlanB
      1978 XS-Eleven
        • 7844
        YOU CANNOT JUST BLOCK THOSE HOLES!!!!!! You need the get the oil feed pipe that WAS in there. That is the feed line to the top end, as in oil supply to the cams! DO NOT RUN THE BIKE WITHOUT A LINE BETWEEN THE TOP AND BOTTOM!!!
        • MrWheelie
          • Dec 2007
          • 92
          • Dallas Texas
          I'll get one made tomorrow.
          1978 XS-Eleven
          • AlanB
            • Oct 2006
            • 705
            • Scotland
            Hi Mr Wheelie,
            What he said!........ Have a look at a manual, fiche, or even a decent pic of the engine; you will see what it should look like.
            They don't go wrong or break..... I bet there are a lot lying in sheds and garages around the membership!
            AlanB
              I agree... all the engines use the same oil line and someone will have one a lot cheaper than having one made.
              • John
                • 5117
                You will need to pay attention to which banjo bolt goes in which hole. They are different lengths. One has an indentation in the head. You will see it when you look for it. That bolt goes in the top hole. I have a spare pipe by the way...
                  Nice of you to brag... but the guy needs an OIL line!
                  When/if you get an oil line, you'll need 2 new copper looking crush washers for each banjo end (4 total). Most any auto stores will have them in the brake parts section.
                  • 79XS11F
                    • Jul 2006
                    • 3563
                    • Ottawa, Ont. Canada
                    As was stated I'm sure someone will have an oil supply line. If you have new copper washers on hand use them ... if not ...
                    I never buy new copper washers... I just heat up the old ones with a plumbers propane torch and (don't MEAT them) then reuse them. Been doing it for years on oil and brake lines with no problems or leaks.
                    Rob
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
                    • mro
                      • Oct 2005
                      • 4276
                      • Hayward, California
                      (don't MEAT them)
                      beef, Poultry, Pork, Pâtés, Veal???
                      or...
                      did you mean not to beat your ...
                      Heard can make you go blind.
                      mro
                      now where did I leave my glasses
                      • 79XS11F
                        • Jul 2006
                        • 3563
                        LOL LOL it's an internet spell checker LOL LOL
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • MrWheelie
                          • Dec 2007
                          • 92
                          • Dallas Texas
                          let me know how much.
                          **Email addy Editted for privacy/security/spambot protection!**
                          Mr Wheelie,
                          It's best to send this type of info in Private Messages(PM's) to help prevent the Spambots from getting your email addy from here since they can read the posts without being a registered member! T.C.
                          1978 XS-Eleven
