I bought a Jardine 4-1 back last spring and rode for over 6 months/3000 miles and the headers did not discolor at all. Now after riding just 3 or 4 times in the last several weeks they have changed to a dark gold. Anyone know why they would go so long without any change and then change so quickly?
Header mystery
Tags: None
Timing is the same, but it is much colder here now. I would have thought that the cooler ambient temp. would have acted to keep the headers cooler, but perhaps there now being a greater swing in pipe temp. has something to do with it, or using the choke more. ???Originally posted by chopper
at a guess ignition timing,or ambiant temprature?Robert
79 SFComment
TEMPERATURE
When the temperature goes up, the air density decreases, thus you have less air available for combustion and your air fuel ratio becomes richer. The same works in reverse. As the temperature goes down, you end up with more air per cubic foot, and without re-jetting your carburetor, the engine will run leaner.
This from a racing article website
Interesting...
Ken TalbotComment
Wow, I never would have guessed that running my bike in colder weather would cause my engine to run enough hotter to discolor the pipes.
Robert
79 SFComment
