Still cant get them off !!
  • gman
    • Mar 2007
    • 42
    • essex, United Kingdom
    Hi guys,
    i have been trying to get the barrels off my 79 xs for a month now, haver soaked them, heated them, frozen them and beat the c**p into them with a rubber mallet and still they will not move. it has become a battle between man an bike now. Any ideas on how i can get these jugs off so i can replace the snapped head bolts.
    Happy Christmas
    Gary
  • randy
    • Dec 2003
    • 4521
    Gary,
    This has worked for others. Turn the crank so cylinders 2&3 are at BDC, stuff rags into cylinders 2&3 and bolt the head on with just the center front & rear bolts.
    Turn the crank with the kickstarter by hand. That should lift the cylinder block off the case.
    • audijunky
      • Apr 2006
      • 707
      • VA
      Mine were stuck pretty bad. I used a short piece of 2x4 on the pry points and a 4 lb. sledge hammer.
      Good luck
      79 XS1100 modified standard
      straight pipe 4-2 exhaust
      Owned 83 Honda V65 Magna
      Owned 02 Vstar 650 classic
      owned 85 Honda Shadow VT 700C
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        Guitar string worked in between the case and cylinder to cut the gasket.
        Thin putty knives hammered in to break the gasket.
        (And you need to use better swear words than "Crap" if you really expect to get results. PM me, and I'll give you a list)
          Pro...
          Just write them in here. It will show up as mostly asterisks, and you can act like Vanna White (But you have to wear a dress... nicer than the ones you usually wear.. and hopefully shave your legs) as we guess the leters.
          • Incubus
            • 1003
            • Austin TX
            Two flat pry bars. First pry at the two points on the front, then on the back. Repeat about 50 times.
            The top end on my 11 was very Zen like. It had become one with everything. Rusted rings kept the pistons from moving. Getting the pistons to move was the real trick. Everything after that was muscle and leverage.
            Do your pistons move?
            Patrick
            XS11F (Incubus, daily rider)
            1969 Yamaha DT1B
            • JWSanders
              • 879
              • White House, TN
              It took me and a friend and 2 rather long prybars over an hour to get the jugs off my spare motor. Tried to be as careful as possible, but still ended up breaking off a small piece of a fin.
              80 XS1100SG
              81 XS400SH
              Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
              A Few Animations I've Made
              • Czekus21
                • 1069
                • Keosauqua (Southeast) Iowa
                Took my nephew and I about 2 days to get the jugs pulled from this 750B model ( twin ) prying at the pry points and alot of PB Blaster, Cuss words, putty knife, rubber mallot and a few beers.
                Don't forget the beers.
                S.R.Czekus
                1-big XS patch
                1-small XS/XJ patch
                1-XS/XJ owners pin.
                Just do it !!!!!
                • EZMoney
                  • Oct 2006
                  • 115
                  • Castlegar, BC,
                  Gary
                  I found that when I took mine apart that it wasn't so much the gasket that was holding the jugs as much as the crud that got down between the head bolts and the jugs. It was like cement. There are a couple of spots that are actually open and will allow dirt to get down in there. I put nuts on the top of the bolts and shocked them both straight down and a little sideways.
                  Just what I found helped.
                  Oh Yes and don't forget the BEERS
                  Ed
                  Ed
                  78/82 XS/XJ mostly made up of parts bikes
                  XS1100 SG 1980 Will restore to original over time
                  • Shappers
                    • Sep 2006
                    • 158
                    • Helsinki, Finland
                    Hi Gary,
                    Have you checked out this thread HERE
                    This seems to be a European problem with the barrels as all the salt and road grit on our roads plug up two stud holes at the front of the barrels.
                    US ones normally come off with a lot of brute force and some choice swear words
                    Good luck..
                    '84 Sport
                    • renegade_xs11g
                      • 462
                      • Mid-Michigan
                      Hey, Shappers..............
                      just noticed your avatar...............
                      Dude, where the hell is your front wheel!!!!!!!!!!!!!!!!!!
                      That must have HURT!!!!
                      My Photo Bucket
                      • Shappers
                        • Sep 2006
                        • 158
                        • Helsinki, Finland
                        It's not me, I'm not that crazy (anymore)!
                        That picture intrigues the hell out of me though...
                        How did he get it up there in the first place and how does he plan to land it ????
                        One of life's little mysteries
                        '84 Sport
                        • TucmanXJ
                          • 108
                          • The Old Pueblo, AZ
                          outta there?
                          gman
                          I say - did they come off, if so please give us the gr-eat @!*% (.... expletive deleted) details.
                          RJN
                          79 XS11 Standard F stock "Big N Blue"
                          • renegade_xs11g
                            • 462
                            • Mid-Michigan
                            Oh, man I was KINDA hoping it was SHAPPERS....
                            Hoping for an explanation....
                            My Avatar is MY truck, I live in it 5 days a week
                            My Photo Bucket
                            • gman
                              • Mar 2007
                              • 42
                              spent the xmas period smacking hell into these barrels but they will not budge. looks like i will try to find another engine as this is nuts !!
