Tach works speedometer does not (HELP). Speedometer has not worked since i bought the bike a year ago. Has new cable on it. I thought it might be the gear in the front hub was stripped,but before i take off the front tire i thought i would try an old trick my father showed me on cars to check to see if the speedometer was broken. You disconnect the cable from the front hub and hook a drill to the end of the cable and run the drill wide open. I did this and the speedometer needle did not move. Will this work? And if so , what next? Can you take the speedometer apart to repair it?
