Vance & Hines 4 to 1 ?
  • mraaaaaaaaaa
    • Jan 2007
    • 49
    • cleveland, ohio
    Hey fellas,
    Any1 have these, they are on ebay now,
    Am runnin 4 pod filters, & was wonderin if I can use them, & if,
    I will have to upgrade My carbs. Dropped a 80 special engine
    onto my 78 frame. Used 82 maxim carbs, that were stock, &
    was smokin all da hogs here in cleveland, all summer, lol.
    Will I need to rejet with the pipes, or what ??
    Thanks in advance !!!
    Andy B. North Coast, Ohio
  • Da-Bubble
    • Jun 2006
    • 353
    • Oklahoma City, OK
    Do you mean THESE?
    I didn't know Gixer pipes would fit the XS11....
    1979 XS11 Special (slightly modified)
    dubbed the "Mad Mosquito"
    MikesXs Pod Filters
    MikesXs 35k Coils
    8mm plug wires
    42.5 Pilots 142.5 Mains
    (Carb tune by GNEPIG Performance)
    Kerker 4-into-1
    Shaved emblems
    Progressive frt springs lowered 1.5"
    Progressive 11.5" rear shocks
    Harley Dyna rear fender chopped
    Custm side mt tag (apparently illegal)
    Custom Dual Headlights
    Lots of time and hard work.
      Hey Andy,
      It may depend on what your plugs look like now! If they are already almost bleach white, then you're probably running a bit lean, and the 4-1 pipes "MAY" cause it to run a bit leaner requiring a little rejetting.
      Hey Bubble, folks are finding GXR carbs to fit, why not pipes!
      The ad talks about a few dents, but says nothing about the massive RUST!
        For a little extra oomph.... swap the 80 cams with the '78 cams.
        • mraaaaaaaaaa
          • Jan 2007
          • 49
          • cleveland, ohio
          4 to 1 pipes
          not those pipes the ebay # is, 260183872680,
          for the NEW vance & Hines !!!
          • mraaaaaaaaaa
            • Jan 2007
            • 49
            • cleveland, ohio
            4 to 1
            plugs are brownish/ white, for the cam swap, just pop the top, & switch the cam, being careful to keep the new one in the same position ??
            • JWSanders
              • 879
              • White House, TN
              Those are jardines...but still. New like that is a rare animal indeed. If i didn't already have a set of nice 'getti pipes I'd be really intersted in them.
              80 XS1100SG
              81 XS400SH
              Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
              A Few Animations I've Made
              • Da-Bubble
                • Jun 2006
                • 353
                • Oklahoma City, OK
                TopCat,
                Now I'm interested! Somebody be a guinea pig and buy those gixer pipes to see if they fit!
                -Bubble
                MikesXs Pod Filters
                MikesXs 35k Coils
                8mm plug wires
                Kerker 4-into-1
                Shaved emblems
                • mro
                  • 4276
                  • Hayward, California
                  Be sure to align the dot on the sprocket with the arrow on the cam cap...
                  Complete instruction in manuals.
                  mro
