Ok Im stumped and pleading for suggestions.
Carbs just rebuilt. Bike will only run with choke fully out
unless revving it over 3grand, you can rev it all you like
it sounds healthy over 3k. Checked and checked for air
leaks by using carb cleaner spray. Ive redone the boots
twice sealing any possible air leak.
Cylinders 2 and 3 are running extremely lean. Black carbon except
for the tips and they are snow white. Cylinders one and four are
a very nice color.
If I spray under the boots of cylinders 2 and 3 there is a definate engine response.
Am I missing an air leak here with the boots? Or is it possible the head gasket is going south and sucking air?
Thanks
J
a very nice color.
Thanks
J
You say you cleaned your carbs, how many times??? If only once, then you only have two more times to go!!! If you have searched and read the previous threads, you'll find that most folks report that they have to clean their carbs 3 times to get them truly clean!!!
