Not much thought into the lagistics of it and not trying to take away from TC's spin on filter adapter, it's just MY PERSONAL PREFERENCE  to not have the oil filter hanging down like it does with his adapters. There are many vehicles that have a remote spot for the oil filter. My old 88 GMC Jimmy has the oil filter up in the left front (Driver's side) of the engine compartment mounted to the fender with oil lines running to/from it. I'm sure something like this could be had pretty cheaply from a salvage yard and run new lines into it, and the filters are small and readily available.
My question is... if I attached one of these to the bike where my air box used to be, (Kind of out of sight behind my sideplates) can you run the oil from the plate that normally feeds the oil cooler, back to the filter behind the engine, then back forward to an oil cooler before returning to the engine? Would this put too much strain on the stock oil pump to have to pump this distance? The lines could be run under and along the insides of the frame so as not to be an eyesore, and using steel lines, it would provide even more cooling than an oil cooler alone.
Just wondering while awaiting my new oil cooler
It's supposed to cool well even with no air blowing across it. We'll see... $30 including shipping off Ebay. Item # 250190576555
Comments?
Comments?
