I have read past threads on the subject and I think I know what to look for but just wanted some thoughts as I am not the most mechanical when it comes to this stuff. It started a while back when after a long trip on the XJ1100 It was leaking into the airbox even with the petcocks tuned off. This subsided after a bit and I assumed it was a stuck float in the carb. After running a tank with Seafoam added to gas to try and clean out the carbs that seemed to take care of the issue. Forward a few months and the leaking is back as I am attempting to winterize the beast. I normally top off the tank and run stabilizer through as I have in the past with no issues. This time i notice fuel spurting out from underneath the motor and becomes more intense as I throttle up higher.
Would the best order of checking be to start with the petcocks and possibly get a rebuild kit for them. Then look at the fuel lines for leaks and finally consider a carb cleaning. Am I missing anything here or am I on the correct track?
Thanks
Thanks
