Vetter head light removal
  • mro
    • 4276
    • Hayward, California
    I have a windjammer fairing with the plastic head light bucket and the retaining ring is plastic too. Looks like the bulb is a single unit, not like reg. H4
    No screws hold the ring on. Bottom center of bucket has a small plastic tap sticking out next to ring.
    Would think that it is for releasing the ring so I tried pushing it one way and then the other and pulling on the ring.
    Ring holding bulb did not come off.
    I'm either missing something or not applying enough pressure???
    Anybody know for sure how it comes off???
    mro
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    I believe I pushed in and turned the ring at the same time to remove the headlight.
    BDF Special
      Round headlight in a Vetter, right? It has been a while, but IIRC, there is a tab that you push in, or up, or some direction, which releases some plastic locking mechanism, which allows you to rotate the assembly slightly CW or CCW, which allows the entire works to come apart. Sorry I can't be more definite, but it has been a nice evening with good friends over a home made stew with a few bottles of nice wine, etc, etc. Maybe tomowrrow morning I'll spend a few minutes with the search tool to come up with the definitive procedure for headlight removal. Or not...
        MRO,
        Push the tab, rotate the ring CCW, remove. Sometimes the ring does NOT want to rotate, so rock it CC and then CCW once or twice to break the dead bugs loose.
        • rockjok
          • 152
          • Montana
          Here's a link to the "official" headlight removal instructions.
          It seems that I need to reference this once a year since I can't seem to recall the procedure.
          Windjammer mounting instructions, Vetter saddlebags mounting, Vetter wiring code, Honda GL1000 vetter mounting, honda 500 vetter mounting, BMW motorcycle vetter mounting, Bob Clarke artwork, Tail trunk, Clipped windshield instructions
          Rob
          • mro
            • 4276
            Thanks rockjok for the site, all I found was a site which showed some of the history of vetter. (have you guys seen his attempt at flying?)
            One thing is that mine is a plastic ring rather than chrome...
            This be on my merriam...bugs?...naw...they would'nt dare@!
            I did push it back, pulled it forward, while pushing, then pulling, and twisting the ring etc.. Did not try pushing tab "in" tho.
            I be strong, er maybe stronger than DiverRay,
            but not as strong as Prom...
            (don't stand down wind of Prom...if ya know what I mean
            Force applied was tempered so not to FUBAR ring/bucket.
            Later today will give it another go. If next pic shows a chrome ring on the bucket...you'll know what happened
            mro
            • prometheus578
              XS-XJ Super Guru (RESIGNED)
              • Aug 2004
              • 4012
              • Olympia , Wa.
              "Must be referring to my "Air of Distinction."
              At least I don't whine about my mechanical inadequacies... or sit around getting "stewed" with my friends(not that I have any).
              "The Prom Way" was to pry the little bugger off first, (thinking it was stuck)... then finding the locking mechanism.
              Motorcycle maints. should always be a voyage of discovery.
              • mro
                • 4276
                phew...
                Well..I be still learn'in
                (and I prefer wine not whine )
                and like to shoot pool while getting stewed, mostly with acquaintances not friends (don't like to take a friends money)
                mro
                burning day light, time to go do something
                • mro
                  • 4276
                  Push in tab and ring un screws...
                  Head light bulb is good....
                  mro
                  • jeffe
                    • Oct 2004
                    • 393
                    • Westerville,Ohio
                    Scroll down on the Vetter website and it will show you how.
                    78E ... Gone but not forgotten
                    2006 Kawasaki Concours....just getting to know it
