front end noise
  • Filter
  • #16
    take it for a spin with the cable removed and you will know if it is involved or not.
    also check up under the front fender for crap that can be contacting the tire or wheel when moving. With the front wheel off the ground can you hear anything when you spin the wheel?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • #17
      front end noise
      Rob, that is something I would have probaly never thought of---
      I'll do it tomorrow and let you know if it was the source.
      dodjh
      Semper Fidelis to my brothers serving on foreign hostile soil
      • #18
        front end noise
        Rob/ all others with feedback,
        After getting over the appearance of my bike after yesterday,
        I unscrewed the speedometer cable at the base and took it for a trial run---No more Noise.
        Does that mean the cable is bad or the guage itself is going out?
        Thanks
        dodjh
        • #19
          Re: front end noise
          Well the cable drive gear will be moving even when the cable is disconnected so if I were you at this point I would spin the cable on t he bench with a drill and see if the noise is recreated. If not and the cable moves freely there is an issue in the speedo itself. DON'T spin it too fast with the drill eh.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • #20
            front end noise
            Hey Rob,
            I'll do that and hope that is the noise maker. I do have a spare set of guages but no spare cables.
            Thanks
            dodjh
            • #21
              Lube it
              Just take it out and put some oil on it and put it back in the housing.
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
              • #22
                While I think I did mention the cable,
                the drive still could be the culpert as w/o the cable connected it has no load. (putting some grease there does not hurt)
                Would hang the cable with a piece if plastic taped around the top portion (like a funnel) then add a little oil. Leave until oil drips out bottom end.
                mro
