XJ stuck in gear,clutch in = no forward
  • XJ stuck in gear,clutch in = no forward
    Was riding my XJ with 1980 XS engine when suddenly oops!
    When: Sat. 11/10/07
    For a week I'd heard a bit of ringing noise as each gear engaged (as the bike slowed). I've been riding it easy, clutching out carefully.
    At first I thought it was a noise coming from under the tank ... IT'S ONLY HEARD IN GEAR, SLOWING DOWN.
    1:00 pm Breakdown
    About 30 mph I downshifted on level ground. Today's downshift engagement (a mid-pitched growl) grew louder as I slowed. Pulled the clutch in and shut it down before any more noise or damage could result.
    3 pm Bike would not roll forward in either nuetral or in any gear, even with the clutch pulled in.
    Got home, took clutch adjust cover off - checked cable & engangement travel, it looks normal. Still no forward - we had to push the bike Backwards to load it onto a trailer.
    Searched forum tech articles & gear discussions - not much found about this PARTICULAR TRBL. Until today the bike had been starting & running well with no other funny noises.
    Lost primary chain? Broken clutch? Seized engine? Anyone have any ideas?
    Rob
    79 XS11 Standard F stock "Big N Blue"
    Siezed middle drive.
    When was the last time you checked the fluid level in there?
    Ken Talbot
      Sounds like it's stuck in reverse
      mro
      Sorry, could not resist
        PM
        Not where to post, but maybe see this. Check your PM Ken T............Thanks!
          Hadn't checked middle drive. Hope that's all it is ... As if that weren't bad enough. Er, Now where did I put that XJ shop manual?
          RJ
            Engine should run ok even if middle gear FUBAR'ed,
            at least in neutral or with clutch pulled.
            mro
              Hey MRO,
              He didn't say that the engine wouldn't run, but that it wouldn't ROLL. I also seem to remember being able to push it backwards vs. forwards might also be the rear brake trying to lock up, so he might want to pop the bleed screw on the rear caliper just to make sure that the brake isn't dragging severely!?
              But it does sound more like the middle drive, whining noise from under the gastank!
              At least, after getting a replacement drive, you could then play with the old one IF you ever thought about a ChainDrive conversion!
                .... WHOLE LOTTA LUBE
                Yep - It WAS indeed the center gearbox. It's 100% toasted.
                1) PO had swapped motors/drives, didn't torque center box's bolts tight enough (they were LOOSE).
                2) Apparently he'd re-used the old gasket - lube was leaking out ... fluid looked like engine oil drips below. Both bearings were dry, shafts turned gray etc. Lucky I stopped before it could lock up the bike at speed.
                3) GEARBOX is frozen unless rotation is reversed. Sounds crunchy. Trashed, zip, gone ....
                Yes ... I shoulda checked the lube level.
                Upon inspection & reflection I think the gearbox was already going out when I bought bike - it was noisy from day one.
                So now I'm XSively seeking a gearbox / gasket etc....
                Argh! RJ
                  pm andreas he prob has a couple
                  when in doubt...get a bigger hammer
                  '78 XS11e, '79 XS11sf,'81 Mazda RX7, '83 XJ650lj Turbo, '95 Ford F150, '93 Chevy K2500, '04 Honda Pilot,
                  '89 Arctic Cat Wildcat, '89 Arctic Cat El Tigre 530, '81 Arctic Cat Trailcat 340, '79 john deere trailfire 440,
                  '78 Cadillac Seville
                  Don't steal the government hates competition
                    Argh reduced to awe shucks
                    Thanks guys ...
                    trbig is assisting w/ one of his spare drives.
                    The Forum rocks more every day.
                    ALL KUDOS to da XS11 CREW
                      Ride the West
                      "I was just following a Yamaha XJ ... the rider said his gearbox was getting a little hot ..."
                      "Is this the end you want?"
