Oh look, a carb question...
  • Pain
    • 476
    • Milwaukee, WI
    The carbs on my 81 H were acting up, so I put the carbs from my 80 SG on them, they went on just fine.
    Now I am putting the SG back together, and want to just put the H's carbs on (simpler), but they will not go on for anything.
    It seems unlikely, but are they a different size?
    I've been in more than one Hemisphere, and I wrote a book to help you do it too (or just prepare better for that week long road trip). Going Small, not just for the little guys.
    • 7654
    They SHOULD be the same size. Did you try a little soapy water or spray silicon lube? My guess is the rubber has gotten harder, and won't stretch like it used to. You could try a quick wipe of a rag with carb cleaner on it, and then plug the carbs in quickly.
    • Crazcnuk
      • Aug 2006
      • 2980
      • Hinton, AB, Canada
      I use just a bit of lubriplate on the inside of the rubber. Seems to work fine, although I can't vouch for the long term effect on the rubber!
      '05 ST1300
      • boyat68
        • Oct 2007
        • 358
        • Virginia
        "Vasoline"
        I use vasoline whenever I need to pre-lubricate anything that uses gasoline, since vasoline is a petroleum product it mixes well with the gas. It also keeps the gaskets softer for a longer period of time
        • Pain
          • 476
          • Milwaukee, WI
          Thanks, I will give it another go
          • LoHo
            • Sep 2002
            • 1341
            • Fresno, CA
            I believe another thread recommended soaking in WD40. You could spray them down, let it sit, spray a few more times, and see if the rubber regains its elasticity. I know that WD40 is not a cure-all (my neighbor calls it "Dust Attracter 40"), but this may be the right job for it.
            • prometheus578
              XS-XJ Super Guru (RESIGNED)
              • Aug 2004
              • 4012
              • Olympia , Wa.
              Heat up and soften the boots with a hair dryer.
              • pggg
                • 1609
                • NZ
                Powder them with lip gloss...
                • xsilerating
                  • Dec 2006
                  • 430
                  • Eastern Ontario, Canada
                  Re: "Vasoline"
                  A bit of a cautionary note... one should NEVER use a petroleum based lubricant (i.e. Vaseline) on rubber products as it will cause deterioration and breakdown of the rubber. You should only use a NON-petroleum lubricant such as Dow 111 or equivalent.
                  1980 XS11 LG (Diablo)
                  1980 XS11 G (Bagger)
                  1978 XS11 G (White Knight)
                  1978 XS11 G (Skeleton)
                  2016 SS (S.S. Flyer)
                  • mro
                    • Oct 2005
                    • 4276
                    • Hayward, California
                    sound like a bunch a wimmin
                    vasoline
                    hair dryer
                    lip gloss
                    mro
                    • boyat68
                      • Oct 2007
                      • 358
                      • Virginia
                      Oh you men!
                      • stoked
                        • Oct 2007
                        • 149
                        • Broken Arrow, OK
                        KY Jelly maybe?
                        79 XS11 special
