Oh look, a carb question...
  • Pain
    • 476
    • Milwaukee, WI
    The carbs on my 81 H were acting up, so I put the carbs from my 80 SG on them, they went on just fine.
    Now I am putting the SG back together, and want to just put the H's carbs on (simpler), but they will not go on for anything.
    It seems unlikely, but are they a different size?
    I've been in more than one Hemisphere, and I wrote a book to help you do it too (or just prepare better for that week long road trip). Going Small, not just for the little guys.
    They SHOULD be the same size. Did you try a little soapy water or spray silicon lube? My guess is the rubber has gotten harder, and won't stretch like it used to. You could try a quick wipe of a rag with carb cleaner on it, and then plug the carbs in quickly.
    • Crazcnuk
      • 2980
      • Hinton, AB, Canada
      I use just a bit of lubriplate on the inside of the rubber. Seems to work fine, although I can't vouch for the long term effect on the rubber!
      '05 ST1300
      • boyat68
        • Oct 2007
        • 358
        • Virginia
        "Vasoline"
        I use vasoline whenever I need to pre-lubricate anything that uses gasoline, since vasoline is a petroleum product it mixes well with the gas. It also keeps the gaskets softer for a longer period of time
        • Pain
          • 476
          • Milwaukee, WI
          Thanks, I will give it another go
          • LoHo
            • Sep 2002
            • 1342
            • Fresno, CA
            I believe another thread recommended soaking in WD40. You could spray them down, let it sit, spray a few more times, and see if the rubber regains its elasticity. I know that WD40 is not a cure-all (my neighbor calls it "Dust Attracter 40"), but this may be the right job for it.
            • prometheus578
              XS-XJ Super Guru (RESIGNED)
              • Aug 2004
              • 4012
              • Olympia , Wa.
              Heat up and soften the boots with a hair dryer.
              • pggg
                • 1609
                • NZ
                Powder them with lip gloss...
                • xsilerating
                  • Dec 2006
                  • 431
                  • Eastern Ontario, Canada
                  Re: "Vasoline"
                  A bit of a cautionary note... one should NEVER use a petroleum based lubricant (i.e. Vaseline) on rubber products as it will cause deterioration and breakdown of the rubber. You should only use a NON-petroleum lubricant such as Dow 111 or equivalent.
                  1980 XS11 LG (Diablo)
                  1980 XS11 G (Bagger)
                  1978 XS11 G (White Knight)
                  1978 XS11 G (Skeleton)
                  2016 SS (S.S. Flyer)
                  • mro
                    • 4276
                    • Hayward, California
                    sound like a bunch a wimmin
                    vasoline
                    hair dryer
                    lip gloss
                    mro
                    • boyat68
                      • Oct 2007
                      • 358
                      • Virginia
                      Oh you men!
                      • stoked
                        • Oct 2007
                        • 149
                        • Broken Arrow, OK
                        KY Jelly maybe?
                        79 XS11 special
