What's interesting is the amount of advance that the XJ specs you stated provide...only max 36 degrees, or perhaps that also doesn't account for any additional advance due to the vacuum boost sensor??
Backing up a bit.....
Engines need to fire spark plugs BTDC (Before Top Dead Center) so the charge can burn and reach full power just as the piston goes past TDC. At the same time you don't want the burn to start to early which would rob the engine of power by putting pressure on the rising piston. The quandry is that piston speed changes but the burn rate does not. To get better performance, the point at which the burn starts needs to be varied with engine speed and load.
Most engines start with a "base timing"; in the XS it is around 15 degrees BTDC. This is known as static timing. When starting your engine the plugs will fire at 15 degrees BTDC. As soon as the engine catches and gets to idle two other factors come into play.
One of these is the curve programmed into the TCI. The other is the vacuum advance mechanism, or in the case of the XJ, the vacuum sensor.
The TCI knows your engine RPM and will produce the advance programmed into it. As RPM rises vacuum drops to the point where it has no effect, leaving the TCI to provide the timing value. In both cases this appears to be 36 degrees at slightly different RPMs, 5200 for the 2H7 and 4RO boxes, 5500 RPM for the 10M box.
So far, so good. Both the 2H7, 4RO, and 10M TCI boxes pretty much agree on the max advance. There is some difference at idle, with the XJ at 15 static + 5 advance or 20 degrees total advance vs the static 15 plus 10 advance or 25 degrees for the '81 models that TC mentions.
So why have a vacuum sensing system? Here is a quote from a Chevy performance web page:
The reason your engine is able to sustain more timing at part-throttle is because only a limited amount of air and fuel make it into the cylinder at part-throttle. Lower cylinder pressures enable the combustion process to start sooner and help improve part-throttle response by increasing torque. This additional part-throttle timing improves efficiency and torque.
Ideal ignition settings will allow your engine to run the maximum amount of timing at all engine speeds without detonation.
I am not even convinced you would get 36 degrees in the middle rpm ranges (3000 - 4000 RPM) since I don't know when the TCI is programmed to produce the 36 value. We know max advance happens by specific RPMs or no vacuum (we think, not proven), but in the lower ranges that leads to a catch-22: if the TCI has no vacuum input, it never detects zero vacuum! Or, without inputs, it defaults to zero vacuum values and puts out the advance based solely on RPM.
The idea that a 4RO box on an XJ would default to putting out 36 degrees of advance at any RPM is unproven. We, or at least I, do not know the advance vs RPM curve. It may be the 4RO jumps to 36 at a very low RPM, but equally it is possible the 36 does not come in until much higher. After all, there is supposed to be a vacuum advance at work that provides additional advance which effect should be more pronounced at lower to middle RPM ranges. Who knows? BTW, when I say "lower to middle RPM" I am refering to 3000 - 4500 RPM, roughly. I do a lot of riding in that range, including most of my shifting. I think thats where the TCI and vacuum advance really work together. Anything over 5000 is high RPM to me.
This arguement is pretty theorhetical. Without further testing or information it is hard to say what the exact effect of running a 4RO box on an XJ is. Still, I would run a 4RO only until I could find a 10M box; I don't think the 4RO would be a good long-term solution for replacing a bad 10M TCI, nor would I promote a 4RO (or 2H7) as such.
However, it does appear that a 4RO should work on the early 11s, as the lack of vacuum-sourced input is made up by the mechanical vacuum advance.
Thge other way around, using a 2H7 on an '81, would appear to be a bad ide for the same reasons using a 4RO on an XJ: you defeat the vacuum advance control of your timing curve and go to the advance vs RPM curve programmed into the TCI. While the engines may run you would be loosing torque and efficentcy at any part-throttle operation, which is where, I suspect, most of us spend the bulk of our riding time.
Again, the loss may not be great. Without numbers to back up these theories they remain just that...theories. YMMV!
They stated that they combined the 10 degrees of static, along with the 26 degrees of Cent. advance AND the 16 degrees of Vacuum advance and came up with 52 degrees!
It's in their article!!!
Another option might be to get the 2H7 mech. timing parts, and then you can put on a 2H7 module, or even make one up out of GM ignition parts since it will work with the mech. adv. parts! JAT!
