I would like to know how you pulled that one off!  Didn't the 81 engine have later type advancer behind the timing plate (ie not centrifugal thing)?  Did your 80 have the 4RO box?
				Originally posted by Crazcnuk
If you are asking whether the 79 pickup will work with the 80 TCI box, I think it depends on which one each of these had. As long as you have both the same seires, ie; 2H7 or 4R0 then your all set.
I am running an 81 engine in my 80, and I didn't have to change anything.
 that they are similar to the mechanical units values since it's still the same engine, although Yamaha may have changed them due to EPA requirements??   But I do know that the 4RO box incorporated the Cent. Adv. Curve into it since that engine doesn't have Cent. Adv. parts on the timing plate/assembly, just vacuum advance.
