4th gear grind
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    4th gear grind
    My tranny grinds upon shifting into 4th , either shifting up or down (down is easier) . It isnt serious enough to slow me down yet , but someday a fix will be necesary . Anybody have this problem on a XJ ?
    Axel
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    yeah when i false neutral, between 4 and 5 or somewhere around there i dread trying to go back into gear, cause i'm always gonna chip a tooth, or maybe someone knows that these things don't chip, then halleujah!!
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
      I have a little bit of a grind, but not much. Try looking under the cover on the left side, and verify the shifter is correctly adjusted. check the "tech tips", transmissions from the main page. It may halp, or at least get you some more time for riding before a "winter teardown".
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        cant find the thread
        I was talking with T.C. (I think) or Trbig about this before but I cant locate the thread . Searching doesnt seem to produce anything on a 4th gear problem . I remember reading why there seems to be a neutral between 4th and 5th but my grind is between 3rd and 4th . All other shifts are smooth except whatever is to be expected going from 1st to 2nd .
        XJ1100K
        Avon rubber
        MikesXS black coils
        YICS Eliminator
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          handy info
          XJ1100K
          Avon rubber
          MikesXS black coils
          YICS Eliminator
