79 XS11 with FJ1200 carbs, ignition troubles?
  • bfreehill
    • May 2007
    • 17
    • boulder,co
    [QUOTE]Originally posted by ae7f
    [B]Your story is of great interest to me, because I'm at 5700ft elev. right now and my 79sf doesn't even come close to the performance you describe.
    1. What is the general condition of your bike's engine? How many miles?
    2. What year of FJ1200 did your carbs come from?
    Hey Ben, my bikes engine has good compression with 36k on it.
    Not sure what year FJ my carbs are from, I think they are all the same.
    79 XS1100
    • bfreehill
      • May 2007
      • 17
      • boulder,co
      Originally posted by bfreehill
      FJ carbs:
      they do bolt up pretty easy.
      the main issues were re-routing the oil feed line and finding a throttle cable with the correct fittings on either end. I also had to make a cable holder at the carbs. (ill post some pics)
      Ben, I went to my local parts yard and went digging for the right cable, the FJ uses a push -pull cable (2 cables) but I went with just the pull. the cable stay on the carbs was the the crux of the job. I cut and re-welded the fj cable holder to work with my new cable. (higher than stock)
      You MUST restrict the vacuum advance line. I used a small pilot jet inline (read this thread, i mention my tech early on), no restriction and the timing advance bangs itself very loudly.
      ill post some pics tomorrow....
      hope this helps.
      The FJ carbs transformed my slug into a smooth running power machine. And with enough weight on the rear of the bike (my 110 pound wife) we get 3rd gear wheelies.
      79 XS1100
      • Shuriken
        • 1093
        • Southwest USA
        They also use a push-pull cable system. I will probably have to get a longer cable for sure. Also, the mains are 124 - I didn't check the pilots. But those will be too rich. I should have some leaner mains anyway.
        I'll see what kind of cold weather motivation I can muster up...
        Ben
        Formerly:
        1982 XS650
        1980 XS1100g
        1979 XS1100sf
        1978 XS1100e donor
        • bfreehill
          • May 2007
          • 17
          • boulder,co
          #34
          I forget my jetting but I left it as it was, 124's sound familiar.
          PICS!
          the cable holder
          notice different threaded end on new cable.
          the oil line has to move to the right, the carb linkage will hit it.
          pilot jet from EX500 for vacuum line.
          the stock air box should work but I used individuals.
          Good luck,
          Brooks
          79 XS1100
          • Shuriken
            • 1093
            • Southwest USA
            #35
            Okay, thanks for that, Brooks.
            My carbs are from the 1985 model.
            So you aren't sure what year/make/model that cable was from?
            Ben
            Formerly:
            1982 XS650
            1980 XS1100g
            1979 XS1100sf
            1978 XS1100e donor
            • Shuriken
              • 1093
              • Southwest USA
              #36
              I'd really like to know what your compression readings were. Do you get anything higher than 120 out there?
              Ben
              Formerly:
              1982 XS650
              1980 XS1100g
              1979 XS1100sf
              1978 XS1100e donor
              • stoked
                • Oct 2007
                • 149
                • Broken Arrow, OK
                #37
                bfreehill, sorry to interupt but could you please tell me where you got that inline filter from? I can't find any around that are that small.
                79 XS11 special
                • bfreehill
                  • May 2007
                  • 17
                  • boulder,co
                  #38
                  Colorado powersports in boulder co.
                  I think they are like 3 bucks ea.
                  79 XS1100
                  • bfreehill
                    • May 2007
                    • 17
                    • boulder,co
                    #39
                    Ben
                    Gosh I wish I knew... I literally dug through a huge pile of cables till I found one with the correct ends that was about 3 inches longer than stock.
                    My comp readings were all around 130.
                    79 XS1100
                    • stoked
                      • Oct 2007
                      • 149
                      • Broken Arrow, OK
                      #40
                      Oh crap!! I found one on ebay but it's freeking 25 bucks. That would be 50 bucks for inline fiiters. Tell me I can find em for cheaper than that.
                      79 XS11 special
                      • stoked
                        • Oct 2007
                        • 149
                        • Broken Arrow, OK
                        #41
                        Thanks!!!!
                        79 XS11 special
                        • Shuriken
                          • 1093
                          • Southwest USA
                          #42
                          Okay, thanks for the info, Brooks. I think your bike and mine should be pretty close, then. I probably won't get around to trying out the FJ carbs on the XS for a bit, at least until I see what the ZRX1200 carbs will do.
                          Ben
                          Formerly:
                          1982 XS650
                          1980 XS1100g
                          1979 XS1100sf
                          1978 XS1100e donor
                          • Shuriken
                            • 1093
                            • Southwest USA
                            #43
                            I am going to do some more testing on my ZRX carbs. Right now they work great. See this thread...
                            I may end up not even trying the FJ carbs. If I do not, is anyone interested in purchasing the ones I have?
                            Ben
                            Formerly:
                            1982 XS650
                            1980 XS1100g
                            1979 XS1100sf
                            1978 XS1100e donor
