She is ready to go!!
  • xszgrider
    • Sep 2006
    • 46
    • El Paso, TX
    I just got her back together, took her for a test ride, and everything looks good. I did the following:
    - new Metzeler Lasertec tires - spun balanced
    - removed and greased the final drive - splines looked good
    - new coils from Mikes XS and wires
    - removed the ballast resistor
    - removed the RLU
    - rewired the headlight with relays
    - installed a Sylvania SilverStar lamp
    - installed the fuse block from TopCat
    - flushed out the brake lines - pads ok
    - new Westco battery
    - synchronized the carbs
    She is handling great, more power and throttle response, and now I have a real headlight.
    Looking forward to this weekend, when I can spend more time on her. This is a fun bike.
    John in El Paso
    1980 Yamaha XS1100G
    2002 Honda Goldwing
    1977 Yamaha TY250
    1973 Yamaha TX750 (future project)
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    sounds great, i'm sure you'll find something else to do...
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • 81xsproject
      • 3185
      • Fortuna, CA
      Very excited for you. I too have brand new Lasertech's installed and between the weather and life, have only put about 25 miles on them
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • 62trvler
        • 23
        • Grand Rapids MI
        What is this FUSE BLOCK from Topcat? Is this a member mod?
          See This Tech Tip in the Mods section for info about fuseblock!
          • 62trvler
            • 23
            • Grand Rapids MI
            Ahhh I did see that one and also another but the email address listed is no longer valid. I'll try the internet and see if I can order this one. Stuck in Iraq so have to do it all online.
            Thanks for the help.
            • edgo
              • Jul 2005
              • 138
              • Tampa FL
              Did you do the pickup coil wire fix?
              Ed
              79 XS1100SF
              78 YZ400E
              81 SR500
              79 RM250
              77 YZ400D
              05 RM250
              78 CR 250 Husky w/TT500 motor
              • 62trvler
                • 23
                • Grand Rapids MI
                No, I just bought a new harness a while back before I found this site. The bike has been sitting for 20 years or more. I travel a lot so haven't had time to do much. Been in Iraq 3 years now so hope to get it going next summer. It used to be a friends bike since we were in high school and he just parked it when it quit running (electrical) so i took it off his hands after looking at it covered in his garage all those years. Probably get rid of it if I don't work on it as i have others I am working on also.
                  62 trvler,
                  If you ride the bike one time, you won't "get rid of it". There are a LOT of bikes out there, but NONE that will do everything the XS1100 will.
                  Just follow the "tech tips" from the MAIN forum page, and it WILL be running well soon.
                  Be safe in country!!!
                  • 62trvler
                    • 23
                    • Grand Rapids MI
                    Thanks, I have ridden one. I used to own a brand new 1980 that I got in a crate when i used to work for Yamaha. It was a factory left over and I got it for $2200.00 in 1986 and watched it put together. Unfortunately I sold it when the kids started coming with 2500 miles on it but she served me well and was the smoothest bike I have ever owned. Whipped a mach mustang one day from a light when he started revving his motor. Buried the speedo and left him in the dust....................................I think he may have gone out and bought one the next day. My buddies father used to have one also so we would take it out sometimes when we were low on gas money and do wheelies down the freeway at 70 mph 2 up, it was a full dresser, stupid but you are bullet proof at tjhat age. He was a great driver and thought of getting him into racing with one of my bikes but were older now and his wife might not let him now.
                    • xszgrider
                      • Sep 2006
                      • 46
                      • El Paso, TX
                      Pick up coil wire fix
                      I am not aware of this fix. What does it involve?
                      Ed
                      John in El Paso
                      1980 Yamaha XS1100G
                      2002 Honda Goldwing
                      1977 Yamaha TY250
                      • BrianB
                        • 362
                        • Idaho
                        Here is a link.
                        1980 XS Eleven Special
                        • Jerry
                          XS & TRUE XJ GURU
                          • 3023
                          • Elma, IA.
                          Speaking of fuse blocks.....
                          Anyone know what became of the ones Indy Rick used to sell? Direct bolt-in replacement, had the advantage of having circuit name and fuse size etched into the aluminum backing plate. One side was for Standards, other was for Specials...there is a little difference in the circuit order, I understand. Mounting holes all drilled and came with corect size bolts.
                          I have one on my XJ which I bought in either '99 or 2000. Turned out it doesn't fit under the XJ side cover, but I am looking at using the backing plate with a newer low-profile block. I think Tkat made them for Indy. Anyway, if anyone knows what happened to Indy (Rick Jamison) please let me know.
                          Jerry Fields
                          '82 XJ 'Sojourn'
                          '06 Concours
                          My Galleries Page.
                          My Blog Page.
