Lower Steering Head Bearing Race Removal
    Hi jwoell,
    you are trying to remove the inner cone & rollers from the lower tripletree shaft?
    Your mantra here is:- "I don't want this bearing, I just want it off."
    Take a big sharp cold chisel and a BFH.
    Put the chisel's edge on the crack between the bottom of the inner cone and the shoulder it rests on and drive the chisel in sideways. That side of the cone will lift. Do it again from the other side. Repeat. The bearing will work itself up the shaft like moving a jammed sash window.
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      That's how I did the last two.
      Though some, I've had to cut a slice in it using a die grinder with a cutting wheel, and then have at it with a chisel.
        • 5062
        Oh it is a complete bearing and not just a race. Sorry.
        • jwoell
          • 63
          • Wichita, KS
          Nope it's just the race left at this point. I pryed enough on the bearing that the rollers and cage got loose enough to remove.
          I'll give it another try tonight and let you know how it goes. Thanks for the suggestions on this, I didn't know it would be this much of a pain when I started
          '81 XS11 SH (XSelsior)
          • scoobes
            • Jun 2003
            • 454
            • formby,which is near liverpool england.
            i use one of these came out a treat [IMG]
            http://i93.photobucket.com/albums/l5...ockremover.jpg[/IMG]
            got it from a building suppliers,
            • jwoell
              • 63
              • Wichita, KS
              I just ended up grinding most of the way through the thing with my 4 inch grinder. Came off fairly easy after that.
              So I got the front end all put back together and wow, what a different that made! It's like a totally different bike, I can't believe it. It's incredible smooth and much much easier to control. The handling has improved tremendously. Night and day difference.
              Thanks for all your advice while I've been messing with this
              • MacMcMacmac
                • Dec 2006
                • 127
                • Ottawa, Canada
                Just FYI, you can usually knock a bearing off a shaft quite easily by putting the edge of a chisel from an air hammer against the race and lightly buzzing it off.
